  3. Gurux.DLMS.UI.Net
Gurux.DLMS.UI.Net
By Cavaser , 24 September, 2017
Known problems
Hi all,
I have a problem with component Gurux.DLMS.UI.Net. When I try to build solution two errors are shown:
1.Identifier expected :static is a key word
2.Expected class,delegate, enum,interface, or struct
This is all related to file GXDlmsUi.cs and line 9.
using static System.Windows.Forms.Control;
Could you check please.
Cavaser
8 years 11 months ago
Gurux.DLMS.UI.Net
Hi Cavaser,
We are building this using Visual Studio 2015 and 2017 without problems. What Visual Studio you are using?
Cavaser
In reply to Gurux.DLMS.UI.Net by Kurumi
Visual Studio 2010 is my version :( Do you have some workaround or this is prereq??
Cavaser
Gurux.DLMS.UI.Net
Hi Cavaser,
Can you download newer version from VS and try with that? Or can you use gurux.dlms.ui component from nuget.org? Then you do not need to build it.
Cavaser
Gurux.DLMS.UI.Net
Yes I will do that till I update VS to latest version. Thanx for help and support.
Cavaser
Varun Sharma
6 years 9 months ago
Gurux.DLMS.UI.Net
Gurux.DLMS.UI.Net
Hi all,
After adding a new form how can i call the ui panles to download data
Could you please help
Varun
Data is got from the COSEM object. Data is updated automatically when you select the COSEM object in GXDLMSDirector.
Varun Sharma
You don,t get it.I am not
You don,t get it.I am not using GXDLMSDirector.
I want to download dlms data like instant profile using gurux library.
Can you help in it.
  • Connecting to meter using Wrapper
  • DLMS Server / Meter emulation in Golang library
  • Unknown Baudrate
  • negative indexing for custom method/attribute
  • System title
  • obedph10
  • FERRUM 26
  • Splin
  • Carlos Ely
  • Sandeep Bajaniya
