  3. Reading Hexing Meter GetObjects Failed Access Error Device Reports a Unavailable
Reading Hexing Meter getObjects failed access error device reports a unavailable
By keenangeorge , 8 April, 2017
Hi Mikko
I am trying to read Hexing meter i have added the manufacture and i can successfully connect to the meter.
However im getting error getObjects failed access error device reports a unavailable when i try to read
Please see logs below
System.Exception: GetObjects failed. Access Error : Device reports a unavailable object.
at GXDLMSDirector.MainForm.ReadDevice(GXDLMSDevice dev)
at GXDLMSDirector.MainForm.Read(Control sender, Object[] parameters)
1:49:28 PM Disconnect request
7E A0 07 03 21 53 03 C7 7E
1:49:28 PM 01:49:28.128 Sent 7E A0 07 03 21 53 03 C7 7E
1:49:28 PM 01:49:28.336 Received 7E
1:49:28 PM 01:49:28.346 Received 7E A0 07 21 21 73 82 50
1:49:35 PM Failed to receive reply from the device in given time.
7E A0 07 21 21 73 82 50 7E
1:49:35 PM Received data
1:49:35 PM 01:49:35.355 Info Closing
1:49:35 PM 01:49:35.401 Info Closed
Could you please point me in the right direction.
Regards
Keenan George
9 years 2 months ago
Hi Keenan George,
I have answered for you already, but I'll add answer here so I can remember it in the future.
Hexing Meter is returning wrong AARE message. AuthenticationRequired flag is not set when using High authentication. This is fixed to GXDLMSDirecor in that way that action message is send always when high authentication is used.
vipermsq
8 years 7 months ago
Hexing working
Hello Mikko
according with you answer is i have a Hexing DLMS can i read with GURUX or not
i have all access password
Hexing
Please, create a new topic if you have a new question. You can read Hexing meters with Gurux products.
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
  • highclassrightway
  • sapran
