  3. Gurux Sampleclient Not Reading Profilegeneric Buffer and Capture_objects
Gurux sampleclient not reading profilegeneric buffer and capture_objects
By mansour , 8 July, 2016
Known problems
I'm testing the sampleclient (java) you provided for reading a profilegeneric object from GuruxDLMSServerExample in this way :
1) I launch the sample DLMS Server with this configuration :
GXDLMSServerSN_47 SNServer = new GXDLMSServerSN_47();
SNServer.Initialize(4060);
--> In GXDLMSProfileGeneric instance I see that the attribute "captureObjects" is correctly populated with clock and register object :
pg.addCaptureObject(clock, 2, 0);
pg.addCaptureObject(register, 2, 0);
2) When the GXProfileGenericUpdater runs it adds values to buffer attribute of GXDLMSProfileGeneric instance
3) When I run sampleclient with this params :
GXDLMSClient dlms = new GXDLMSClient(false, 16, 1, Authentication.LOW, "password", InterfaceType.WRAPPER);
--> in GXCommunicate.readProfileGenerics() I can see that "entriesInUse" and "entries" are correctly read but attributes "buffer" and "capture_objects" from "pg" instance that are read on client side are always empty...
--> Can you please complete the sample in order to see how to properly read the attributes "buffer" and "capture_objects" from a ProfileGeneric object ?
Mansour
8 years 10 months ago
sampleclient
Hi Mansour,
I'm so sorry that I have not answer for this question. For some reason I have not noticed it.
Someone reply spam for this and I noticed it accident.
Is this problem still active or have you solved it?
  • Connecting to meter using Wrapper
  • DLMS Server / Meter emulation in Golang library
  • Unknown Baudrate
  • negative indexing for custom method/attribute
  • System title
  • obedph10
  • FERRUM 26
  • Splin
  • Carlos Ely
  • Sandeep Bajaniya
