By 1100modd , 4 March, 2015 Hello friends ! Im tryng to coonect Actaris ACE3000 type 520 with GXDLMS Director but without succsess.... device properties Start Protocol : IEC Media:serial Authentication: Low Local name referencing : yes Password: ******** Wait time:5 Client address: 16 Address type: default Physical Server:11 Logical Server:1 Please help me with correct settings /GX Director/Editor/ for this meter . i have tested connection with Test1107.exe (meter-test) and it reads the meter.. log ==> /?!0D>0A> == /ACE53K520 ==> 06>0500D>0A> == -- STX -- == C.1( 1401******) == 0.0.0( 1401******) == F.F(0-1-0) == 0.1.0(01) == 0.9.1(13:46) == 0.9.2(27-11-14) == 1.8.0(000000.0*kWh) == 1.8.1(000000.0*kWh) == 1.8.2(000000.0*kWh) == 2.8.0(000000.0*kWh) == 1.6.0(00.00*kW)(01-01-70 00:00) == 0.1.2*01(27-11-14 12:39) == 1.8.0*01(000000.0*kWh) == 1.8.1*01(000000.0*kWh) == 1.8.2*01(000000.0*kWh) == 2.8.0*01(000000.0*kWh) == 1.6.0*01(00.00*kW)(01-01-70 00:00) == 0.1.2*00(01-01-70 00:00) == 1.8.0*00(000000.0*kWh) == 1.8.1*00(000000.0*kWh) == 1.8.2*00(000000.0*kWh) == 2.8.0*00(000000.0*kWh) == 1.6.0*00(00.00*kW)(01-01-70 00:00) Please help connecting ACTARIS ACE3000 type 520 Hi, Your meter is using IEC62056-21. This means that you can't use GXDLMSDirector to read your meter. You need IEC62056-21 application to read your meter. BR, Mikko
