By pierrej, 18 December, 2014
We've got a Itron SL7000 761 meter. I managed to read the OBIS codes from the meter (Authentication: Low, IEC), but the OBIS codes for the load profile are not there. The ones I'm interested in, are:
Active Energy Aggregate: 1.1.1.29.0.255
Import Apparent Energy Aggregate: 1.1.9.29.0.255
Import Reactive Energy Aggregate: 1.1.3.29..0.255
The Load Profile Generic codes that are there, gives the "Access Error : Device reports scope of access violated" error, reported elsewhere on this forum.
SL 7000 is older meter and it is not fully DLMS/COSEM compatible.
Everything else works OK, but profile generics (historical data) is not implemented
in standard way. They have implemented it in own way.
We will check this tomorrow if we can find a way to fix this.
We could read all load profile values we require (for the SL7000), by using the Gurux objects, and we are generating a load profile file, with the correct values, but the only thing I cannot work out is to calculate the "End Of Period" values, does somebody know how to do that? I'm pasting the GuruX output as well as the AcePilot output underneath:
Thanks, but the DateTime fields I'm looking for are for the End Of Period of the load profile periods, the DateTime fields you are referring to is when there is a power up/down on the meter and the DateTime gets logged.
I've also sniffed the serial port when AcePilot reads the load profile, but can not work it out from there either, but there must be a way AcePilot is calculating the End of Period times.
When there is no error on the meter, no time gets send back to the client, except if one must specifically ask for an OBIS code for the End of Period DateTimes.
Actaris SL 7000
ACE6000
Thanks for the response, we have an ACE6000 (Itron) meter, with exactly the same symptoms.
Regards
Pierre
Not All OBIS Codes Read by GXDLMS/COSEMDirector
Hi Pierre,
We updated new version from GXDLMSDirector.
We improved Actaris SL 7000 and ACE 6000 support.
All COSEM objects are not implement to the Actaris meter and meter returns wrong error code for that (access violation).
Get latest version and let me know if you still have something.
All profile generics data is not shown correctly because Actaris is using own, non standard way to show data.
Hi Mikko, Thanks a lot, I
Thanks a lot, I will try it and get back to you.
Regards
Pierre
Output from "Load profile with recording period 1" not correct
I'm reading 0.0.99.1.0.255 from the meter (SL7000), but the output doesn't seem right, can I paste you a screenshot somewhere?
Regards
Pierre
Regards
Pierre
Hi Pierre,
You can send it to me. We will check it on begin on next week.
You can find my contact info here:
http://www.gurux.fi/AboutUs
End Of Period DateTime
GuruX:
07 DE 0C 12 FF 0F 13 12 FF 80 00 FF | 000000 | FF FF FF FF FF 0F 14 15 FF 80 00 FF | 000000 | 0 | 0 | 0 |
FF FF FF FF FF 0F 1C 22 FF 80 00 FF | 000000 | 0 | 0 | 0 |
FF FF FF FF FF 0F 20 22 FF 80 00 FF | 000000 | FF FF FF FF FF 0F 1E 15 FF 80 00 FF | 000000 | FF FF FF FF FF 0F 1E 1C FF 80 00 FF | 000000 | 0 | 0 | 0 |
FF FF FF FF FF 0F 26 2D FF 80 00 FF | 000000 | 0 | 0 | 0 |
0 | 0 | 0 |
6 | 6 | 1 |
7 | 8 | 1 |
8 | 7 | 1 |
7 | 7 | 1 |
7 | 8 | 1 |
7 | 7 | 1 |
8 | 7 | 1 |
7 | 7 | 1 |
7 | 8 | 1 |
7 | 7 | 1 |
AcePilot:
End of Period Channel 1 (Wh) Channel 2 (VAh) Channel 3 (varh) Events
18-12-2014 03:20 PM 0 0 0 "Power Cut:
Measurement Start Start 03:19:18 PM
Short Period Start 03:19:18 PM End 03:20:21 PM
03:30 PM 0 0 0 "Power Cut:
Short Period Start 03:28:34 PM
03:32 PM 0 0 0 "Power Cut:
Short Period End 03:32:34 PM
Power Cut Time 1 03:30:21 PM Time 2 03:30:28 PM
03:39 PM 0 0 0 "Power Cut:
Short Period Start 03:38:45 PM
03:42 PM 0 0 0
03:45 PM 6 6 1
03:48 PM 7 8 1
03:51 PM 8 7 1
03:54 PM 7 7 1
03:57 PM 7 8 1
04:00 PM 7 7 1
04:03 PM 8 7 1
04:06 PM 7 7 1
04:09 PM 7 8 1
04:12 PM 7 7 1
The values I require to calculate/read are 03:20 PM, 03:30 PM, 03:32 PM, 03:39 PM, 03:42 PM etc.
Actaris meter do not fully support COSEM standards with profile generics (historical data).
It returns array of values where 07 DE 0C 12 FF 0F 13 12 FF 80 00 FF is date time.
You can get correct date time value using GXClient's ChangeType.
Please let me know your thoughts.
Pierre
Hi Pierre,
Try to get "Logical Devices SL761 (International) - 5.35"
document. It will explain how to handle Actaris SL 7000 and ACE 6000 meters.
