Sorry , I do not fully understand. As I know , there should be some guidelines for the meter manufacturer to follow so the meter can comply to the DLMS standards and there also should be a more specific guideline on how to transmit the data and under which format, correct?
It doesn't matter if you are implementing water, gas, or electric meter, the idea is the same. Only the measurable quantity changes.
You can use this as a template.
https://github.com/Gurux/GuruxDLMS.c/tree/master/Arduino_IDE/server
You can find the standards where DLMS meters are based from here:
You will find an example meter for DLMS here:
