By ichsan05, 31 March, 2022 Forums DLMSDirector Hello I'm trying to connect to my EDMI MK7MI using RS-232 but it always give me invalid wirelessMbus frame response and cannot connect to the meter, i'll attach the following response from notification side on DLMSDirector 31/03/2022 15:02:08 <WirelessMBus len="17" > <TargetAddress Value="44" /> <SourceAddress Value="33" /> <PDU> <Data="334433443344" /> </PDU> </WirelessMBus> Invalid WirelessMBus Thank you. Hi, Hi, Can you add raw data so I can check what framing your meter is using? BR, Mikko Thank you for fast response, Thank you for fast response, this is the raw data : 1. A9 3A A0 23 21 0 2 0 47 73 C3 C7 81 80 14 5 2 1 60 6 2 1 60 7 4 0 0 0 1 8 4 0 0 0 1 DE 89 7E 2. 0 37 1A A0 23 21 0 2 0 47 73 C3 C7 81 80 14 5 2 1 60 6 2 1 60 7 4 0 0 0 1 8 4 0 0 0 1 DE 89 7E Hi, Hi, This frame doesn't look correct. There is UA reply, but the frame is invalid. Check your serial port settings. Try to connect with GXDLMSDirector. BR, Mikko Log in or register to post comments
