  3. How To Change The Access Right of Object
How to change the access right of object
By kytsai41 , 16 December, 2021
The older version can change the access right of object before.
After upgrading to the new version, the access right can not modify.
kytsai41
4 years 7 months ago
the older version
the older version
You can't change the access rights. The meter gives access-right levels when the association view is read. It was possible to change the access-right level in the old version, but that was removed because it was causing so many misunderstandings.
Select "File" and "Refresh" to update access rights for your current association.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
