  3. Unable To Write Load Value Into Meter
Unable to write load value into meter
By hridendra27 , 23 November, 2021
GXDLMSLimiter lm = new GXDLMSLimiter("0.0.17.0.0.255");
GXDLMSRegister obj=new GXDLMSRegister("1.0.1.7.0.255");
lm.setMonitoredValue(obj);
lm.setmonitoredAttributeIndex(2);
lm.setThresholdNormal(new GXUInt32(1000));
writeObject(lm, 4);
I am able to set but value is set zero
4 years 9 months ago
Can you get a hex trace from send and received bytes? Trace from writing the value is enough.
hridendra27
Hi ,
Hi ,
Please find the trace
TX: 00 01 00 30 00 01 00 29 DB 08 49 48 4D 31 32 33 34 35 1E 30 00 00 D8 10 96 72 FE 70 8E 48 73 63 9B 76 19 1C 69 24 F5 CA A1 C9 05 FA 68 B0 CB 23 2C
RX: 00 01 00 01 00 30 00 25 DB 08 49 48 4D 01 70 A7 D8 DB 1A 30 00 00 D3 76 07 69 C4 75 09 9B 35 58 4C B6 4C 71 B4 21 C4 AA 92 6D FF 03 87
hridendra27
Hi ,
Hi ,
I try to set values from gurux dlms director also but it also set 0 value for the laod Limitter.
Hi Hridendra,
Hi Hridendra,
Can you share the block ciphering and authentication keys or send them to me by email?
I need them to check the bytes.
This is get, not the Set (write) message.
<GetRequest>
<GetRequestNormal>
# Priority: High, ServiceClass: Confirmed, Invoke ID: 1
<AttributeDescriptor>
# Limiter
<ClassId Value="0047" />
# 0.0.17.0.0.255
<InstanceId Value="0000110000FF" />
<AttributeId Value="04" />
</AttributeDescriptor>
</GetRequestNormal>
</GetRequest>
hridendra27
I only found this in My Trace How do I get Write trace ?
Check that your writeObject method is wring the data, not reading.
hridendra27
Hi ,
Hi ,
I found the issue. Now am able to write the object. Thanks for help and support.
Thanks for letting me know that this is solved.
