  3. Director Authentication - Serial Connection
Director authentication - Serial connection
By DylanClark , 4 October, 2021
I am having trouble authenticating on the Director.
Meter - Landis+Gyr E650
Connection method - Optical Eye (Serial)
I can connect with MAPs software using password '00000000' but I am unable to in DLMSDirector. I did see another post in the forums about this but I couldn't make sense of it.
Trace from DLMSDirector:
10:21:43
<HDLC len="9" >
<TargetAddress Value="1" />
<SourceAddress Value="11" />
<FrameType Value="93" />
<Snrm>
</Snrm>
</HDLC>
10:21:43
<HDLC len="1D" >
<TargetAddress Value="11" />
<SourceAddress Value="1" />
<FrameType Value="73" />
<PDU>
<Ua>
<MaxInfoTX Value="128" />
<MaxInfoRX Value="62" />
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Ua>
</PDU>
</HDLC>
10:21:43
<HDLC len="43" >
<FrameType Value="10" />
<PDU>
<AssociationRequest>
<ApplicationContextName Value="SN" />
<MechanismName Value="Low" />
<CallingAuthentication Value="3030303030303030" />
<InitiateRequest>
<ProposedConformance>
<ConformanceBit Name="Read" />
<ConformanceBit Name="Write" />
<ConformanceBit Name="UnconfirmedWrite" />
<ConformanceBit Name="InformationReport" />
<ConformanceBit Name="ParameterizedAccess" />
</ProposedConformance>
</InitiateRequest>
</AssociationRequest>
</PDU>
</HDLC>
10:21:43
<HDLC len="35" >
<FrameType Value="30" />
<PDU>
<AssociationResponse>
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="0D" />
</ResultSourceDiagnostic>
<InitiateResponse>
<NegotiatedConformance>
</NegotiatedConformance>
<NegotiatedMaxPduSize Value="0960" />
<VaaName Value="FA00" />
</InitiateResponse>
</AssociationResponse>
</PDU>
</HDLC>
10:21:43
<HDLC len="1D" >
<PDU>
<Ua>
</Ua>
</PDU>
</HDLC>
Thanks! :)
4 years 9 months ago
Is this Trace from another post or is it from GXDLMSDirector? This trace shows that the connection is established successfully. What is the problem?
DylanClark
Hi Mikko
Hi Mikko
Sorry about the confusion. The bottom was trace from MAP110. I have removed it. The trace above is from GXDLMSDirector.
I cannot get write access. Using Authentication = Low and password '00000000'
I received 'Connection is permanently rejected. Authentication Failure'
I checked the MAP110 trace before you removed it and it was using High authentication. What did you try to write? You can usually write only clock and some other values when using Low authentication.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
