  3. After Sending TX Frame Data Send Failed Coming.
After Sending TX frame Data send failed coming.
By Ashok_Chowdary , 1 October, 2021
in Gurux client while reading object after sending the TX frame we are getting as like
i checked with other client software it working fine.
in Gurux I am facing this issue.
4 years 11 months ago
The meter doesn't reply if one of your settings is wrong. If you can add hex trace from another application I can check the correct parameters.
