  3. Problem of Compilation of ARDUINO IDE Client.ino
Problem of compilation of ARDUINO IDE Client.ino
By prasad , 17 April, 2021
Known problems
C:\Users\Ajit\AppData\Local\Temp\arduino_build_722696\sketch\src\client.c:70:9: error: implicit declaration of function 'bb_init' [-Werror=implicit-function-declaration]
bb_init(reply);
I am getting the below error while Compiling the Client.ino, I had uncommented the #define DLMS_IGNORE_SERVER and #define DLMS_IGNORE_IP6_SETUP , Thanks for the support in advance
5 years 6 months ago
What version from Arduino IDE you are using and what board you are using?
I did test this and it worked without problems with Arduino IDE 1.8.12.
prasad
I am using the Arduino IDE 1
I am using the Arduino IDE 1.8.5 and using esp8266 board Nodemcu
open gxignore.h file and add this line:
#define ESP_PLATFORM
bb_init is used elsewhere in ESP platform.
prasad
Thank you i am able to
Thank you i am able to Compile the code
This is now improved and define settings are set automatically. Get the latest version.
  • ZilvinasN
  • Yosr
  • albino.ramon
  • JosepM
  • Aibek
