  3. ISKRA MT372
ISKRA MT372
Profile picture for user rafamarca
By rafamarca , 1 April, 2021
hi folks,
I bought on ebay an ISKRA MT372 just to have a meter to test real communication with GuruxDirector.
The thing is that when the reader answers the AARE I get a permanent reject :
4: 7E A0 39 21 02 23 30 70 EC E6 E7 00 61 2A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0C BE 11 04 0F 08 01 00 06 5F 1F 04 00 00 1C 1D 04 00 00 07 D5 26 7E
<HDLC len="38" >
<TargetAddress Value="10" />
<!-- Logical address:1, Physical address:17 -->
<SourceAddress Value="91" />
<!-- AARE frame. -->
<FrameType Value="30" />
<PDU>
<AssociationResponse>
<!-- PermanentRejected -->
<AssociationResult Value="1" />
<ResultSourceDiagnostic>
<!-- AuthenticationMechanismNameReguired -->
<ACSEServiceUser Value="12" />
</ResultSourceDiagnostic>
<InitiateResponse>
<NegotiatedQualityOfService Value="0" />
<NegotiatedDlmsVersionNumber Value="6" />
<NegotiatedConformance>
<ConformanceBit Name="Get" />
<ConformanceBit Name="Set" />
</NegotiatedConformance>
<NegotiatedMaxPduSize Value="1024" />
<VaaName Value="7" />
</InitiateResponse>
</AssociationResponse>
</PDU>
</HDLC>
It seems that I need an authentication method to connect to the meter even when I use client address 0x10. Do you know how can I get over this? Is it possible somehow to find out encryption level and key? is it posible to set the meter to factory settings?
Thanks a lot in advance
5 years 3 months ago
You can't connect without authentication. Change Authentication level to Low and use password 12345678.
rafamarca
Thanks a lot it worked perfectly!! Now I have communication with the meter...
Is this a ISKRA feature or all the meters work in the same way? I thougth you could connect to any meter using the default address 16 (0x10) for the client meaning no security...
It is more than likely that in a near feautre I would have to read other meters from different brnads and if authentication is required It would be very useful to me to have an idea of the different scenarios I could find...
Again thanks a lot for your support!
It depends on how the meter is configured. :( You can usually connect without authentication, but sometimes the metering company wants that you can't connect without authentication.
Meters are very different and the parameters are depending on the meter.
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
