  3. T_HDLC_FRAME_N5 CTT Test Failed
T_HDLC_FRAME_N5 CTT test failed
By Ashok_Chowdary , 25 February, 2021
T_HDLC_FRAME_N5 /HDLC test #8 failed in gurux director ctt tool and ctt 3.1 standard 64-bits release 107 also
T_HDLC_FRAME_N5:: Unknown command identifier :: FAILED(Response not FRMR)
Starting HDLC tests #8.
Failed.
<a href="https://www.gurux.fi/gurux.dlms.ctt.tests#hdlc8">Test #8 failed.
please help why it is failed?
where I have to check this in the stack?
5 years 6 months ago
This has also changed for version 107. This is the result of version 106.
T_HDLC_FRAME_N5
1: Unknown command identifier PASSED
2: Check that the HDLC layer can be initialised PASSED
I need to ask what is the expected result now.
I know the reason now. We have improved one other error handling and it causes that this fails. This is easy to fix and the new version is released today.
Ashok_Chowdary
Thank you for Reply,
I will check that in New release.
Hi Ashok,
Hi Ashok,
We improved something else some time ago and didn't realize that this improvement will break HDLC tests. There is a new version available where this is fixed.
http://www.gurux.fi/node/17965
