  3. Push Configuration: Class 40
Push configuration: class 40
By sesaomz , 14 January, 2021
I am developing class40 object. For the attribute number 3 "send_destination_and_method" I have to set the IP address of the connected management client. When I browse for it in the following object (image) but I can't see the field in which I have this IP address. ¿Where can I see it in gxdirector??
Thanks a lot for your help!!
5 years 8 months ago
This information is available in Push Setup object, not in Association Logican Name object.
sesaomz
5 years 7 months ago
Thanks for your response. The fact is that in the server, for push operation, I have to use the DLMS association context that is active for a management client when the push operation starts. So I have somehow to extract the destination IP from the association object, and I can't see where.
Thanks in advance one more time!
In reply to Hi, by sesaomz
I'm sorry for the slow reply. I was missed a few questions. The IP address is not tight to the association object.
You might add several push objects. One for each association view to handle this.
