  3. Stop and Delete Task By Schedule
Stop and delete task by schedule
By MNN , 13 August, 2020
Gurux.DLMS.AMI
Hello.
I start reading the attribute on a schedule using AddScheduleTarget. After the task completes successfully, I need to stop the scheduled task.
When I try to delete the schedule (using DeleteScheduleTarget ) an error occurs in ReaderService.
How to do it right?
6 years 2 months ago
Why you do need to stop it? You can run it only once if you set execution time and don't use asterisks (*) in the date-time value.
Your value must be like this:
"Schedules":[1],
"Attributes":[2]
Where 1 is a schedule ID and 2 is an attribute ID.
MNN
Hello.
Hello.
A weak communication channel is used, the task is to poll the device on a schedule. When the task completes successfully (data is received), it must be deleted (from the table GXScheduleToAttribute).
It is possible to delete a task that cannot be successfully completed within a specified time or has been unsuccessfully completed a specified number of times?
6 years 1 month ago
At the moment a task is marked as executed if it fails and it's not trying again.
I propose that after the reading you will go throw all the failed reads and read them again.
This makes reading faster.
MNN
6 years 1 month ago
Hello.
Hello.
Sometimes when the tasks accumulate, the following tasks are not launched. If you clear the GxTask table, tasks are queued again. And I would still like to be able, if not to delete, then at least stop tasks that are running on schedule.
6 years 1 month ago
HI,
HI,
After the listener has accepted the task and is executing it, it's not possible to cancel it.
You can delete tasks with DeleteTask. Like this:
http://localhost:64881/api/Task/TaskDelete
Body is:
"Ids":[1, 2, 3, etc...]
MNN
5 years 10 months ago
Hello.
Hello.
I need to start reading the attribute by schedule and reading until it is read. After that, I need to delete the required record from the GXScheduleToAttribute table, since you no longer need to read the attribute.
I use api DeleteScheduleTarget, sending the package {"Attributes": [3618], "Schedules":[4]} and an error occurs.
How can I stop the schedule?
System.NullReferenceException
HResult=0x80004003
Message=Object reference not set to an instance of an object.
Source=Gurux.DLMS.AMI
StackTrace:
at Gurux.DLMS.AMI.Reader.ReaderService.<DoWork>d__13.MoveNext() in ..\Gurux.DLMS.AMI\Reader\ReaderService.cs:line 398
  • hezhangnihao@163.com
  • ZilvinasN
  • Yosr
  • albino.ramon
  • JosepM
