  3. ECDSA Authorization
ECDSA authorization
By Valeriy , 20 July, 2020
Hello!
How to add a certificate for ECDSA authorization in Gurux Director (and later in AMI)?
6 years 2 months ago
GXDLMSDirector support for ECDSA is released in August.
Valeriy
Just to be able to plan my
Just to be able to plan my work - what part of August?
And one more question - is there a way to add support by editing XML in Director?
Will it work with Ami?
The plan is that it's released to the our clients in 17th and open source version latest 31st.
What XML do you mean? Data, XML translator, etc.
Support for AMI is coming in the next phase. We try to release it soon after the GXDLMSDirector release.
Valeriy
What XML do you mean? -
What XML do you mean? - Gurux Director -> Device Properties -> XML tab.
I thought that there is no support just in user interface but can be written directly to XML configuration of the device.
The purpose of that XML is get device settings in XML format. This helps if we need to compare settings between different meters. Communication might fail if one of the settings is different and this is great way to compare settings between the meters.
Valeriy
6 years 1 month ago
A bit more questions:
Supporting in AMI - not enough only settings change? Are there any big addons required?
6 years 1 month ago
ECDSA authentication is coming just updating the Gurux libraries. Only that is changing for the AMI is saving the certificate to the database or the file.
Profile picture for user AKR
AKR
6 years ago
I also had a need to use encryption.
Is there any news on the realization in AMI?
Best Regards,
Karen.
6 years ago
Hi Karen,
Hi Karen,
Tests for ECDSA are on progress. I believe that it's released for GXDLMSDirector before the end of this month. Support for Gurux.DLMS.AMI is coming soon after it.
AKR
5 years 7 months ago
Any news on support encryption?
Best Regards,
Karen.
We have tested ECDSA for a few months now and I hope that we can release it during this week for C#, Java and GXDLMSDirector.
