  3. "The Number of Columns Does Not Match"
"The number of columns does not match"
By anudeep02 , 16 July, 2020
Hello Mikko,
While testing for profile generic Interface class, I'm facing issue while reading profiles. Initially when default capture objects are present, and I try to read the profile, it read successfully with correct data, and number of profile entries. But when I add capture object from GuruxDlmsDirector, and try to read the profile I'm getting "The number of columns does not match" error dialog box.
Add and remove options in dlms director, are they for viewing purpose only?. Modifying it, doesn't actually add that obis code in profile. Does set operation is nor performed in this case?
Thank you & regards,
Anudeep
6 years 3 months ago
Hi Anudeep,
Hi Anudeep,
I believe that you need to refresh the object list after you have added the objects. Select profile generic you want to update and then select "Refresh" from "File" menu. It'll update capture objects.
