  3. Setting of Push Schedule To Meter
Setting of Push schedule to meter
By Remith , 19 May, 2020
I want to configure/schedule push in meter from my HES using Gurux Java client.
Can you help/give me some sample code block to schedule instantaneous(0.0.25.9.0.255) data?
6 years ago
The best way to get started is if you use GXDLMSDirector to config your Push Setup object. Select Push Setup object and add objects that you want to send in Push message. You can test it using Push-button. It'll generate push message right away.
When you have an idea from this, it's straightforward to add it using Java.
Remith
6 years ago
Hi, I am trying with a
Hi, I am trying with a dynamic IP meter.(Meter is in another country) That's why directly trying with Java code. Please give me a block of code that can be used for setup the push.
Thank you
6 years ago
Remove your email address, or you are getting a lot of spam.
You add objects that you want to push to the object list and write it to the meter.
You can try to read it fist to get an idea from it.
