By Mohanraj , 13 May, 2020 Forums General discussion Hi Mikko, How to set retry setting(Timeout value and retry count) in ANSI C library. Example is In DLSMExplorer for any of the TX packet no response DLMSExplorer will resend the same command. Thanks Mohan Raj Hi, Hi, You just resend generates bytes if you are not receiving the reply from the meter. BR, Mikko Hi Mikki, Hi Mikki, In ANSI C library project where exactly should I add the code to retry? Please provide inputs Thanks Vijay Hi, Hi, Check readDLMSPacket. BR, Mikko Hi Mikko, Hi Mikko, Thanks. Got it Thanks Mohan Raj
Hi Mikki,
Hi Mikki,
Vijay
Thanks. Got it
Mohan Raj
