  3. Unable To Write Load Limit Object Threshold
Unable to write Load Limit object threshold
By Mohanraj , 1 May, 2020
We are trying to write load limit (Normal threshold value). But failed. below is the code snipet and trace. could you please correct what is wrong?
Code Snippet:
gxLimiter limiter;
dlmsVARIANT var;
var_init(&var);
var.vt=DLMS_DATA_TYPE_UINT32;
var_setUInt32(&var,19200);
memset(&limiter, 0, sizeof(limiter));
limiter.base.objectType = DLMS_OBJECT_TYPE_LIMITER;
hlp_setLogicalName(limiter.base.logicalName, "0.0.17.0.0.255");
cosem_setLimiter(&limiter,&connection->settings,4,&var);
ret = com_write(connection, &limiter.base, 4);
return ret;
Trace:
updateInvocationCounter
RX: 7E A0 07 03 21 93 0F 01 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 30 00 07 B2 6C 7E
TX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 8A BE CF 21 7E
Invocation counter: -1407939905 (0xFFFFFFFFAC148ABF)
RX: 7E A0 07 03 21 53 03 C7 7E 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
InitializeConnection
TX: 7E A0 07 03 61 93 69 47 7E
RX: 7E A0 07 03 61 93 69 47 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8A BF 15 24 9A 5F 16 A4 97 D8 C4 4A 0C 01 F2 12 D8 C5 6E D3 DE 03 EC EA 7E 69 60 40 E3 FE 7E
RX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8A BF 15 24 9A 5F 16 A4 97 D8 C4 4A 0C 01 F2 12 D8 C5 6E D3 DE 03 EC EA 7E 69 60 40 E3 FE 7E 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 39 30 38 33 34 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 05 C5 27 38 A4 45 F3 59 82 23 39 C5 26 AF 64 D5 8D C6 8D C8 18 C8 83 7B 7A 74 5E 2C 60 3D 7E
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8A C0 46 8C C1 3E C5 9F 0C DA CD 33 95 CE 98 75 F7 1A F4 40 A6 C7 37 89 F7 DC A1 EF DA D2 AC A1 C0 33 33 16 71 06 5E B7 26 0A 31 F4 01 97 19 7E
RX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8A C0 46 8C C1 3E C5 9F 0C DA CD 33 95 CE 98 75 F7 1A F4 40 A6 C7 37 89 F7 DC A1 EF DA D2 AC A1 C0 33 33 16 71 06 5E B7 26 0A 31 F4 01 97 19 7E 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 05 C6 CD B3 EF 15 43 63 5A AA F5 16 B6 C4 B3 8E B9 79 88 A1 87 B7 73 7D 51 AE 6B C1 A0 65 0D 0E E7 CA 81 72 AB 5F 4E 8E 7E
Writing Limitter
TX: 7E A0 2D 03 61 54 27 A6 E6 E6 00 C9 1F 30 AC 14 8A C2 48 8B A6 3F C6 24 03 00 00 FB 1C 58 C7 73 5F 27 55 9E 7E 0C 0A 23 E1 0F 9E FB 73 FB 7E
RX: 7E A0 2D 03 61 54 27 A6 E6 E6 00 C9 1F 30 AC 14 8A C2 48 8B A6 3F C6 24 03 00 00 FB 1C 58 C7 73 5F 27 55 9E 7E 0C 0A 23 E1 0F 9E FB 73 FB 7E 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 05 C7 EF 95 91 7F 8E C5 BF EC A2 81 82 97 AF CB 10 B8 63 B6 7E
Write failed Limiter 00.00.17.00.00.255:4 Access Error : Device reports a inconsistent Class or Object.
Mohan Raj
6 years 3 months ago
Hi Mohan,
Hi Mohan,
Check your client address.
Mohanraj
In reply to Hi Mohan, by Kurumi
Thanks for your reply. Client address is correct. This is how I am invoking the program. But still failed. Below is the trace.
./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 48 -s 1 -a High -P "0000000001035820" -C "AuthenticationEncryption" -g "0.0.0.1.0.255:2" -v "0.0.43.1.3.255" -t "Verbose" -I
RX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 8B 2A BA EA 7E
Invocation counter: -1407939797 (0xFFFFFFFFAC148B2B)
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8B 2B DD EE C8 28 B0 22 0B A9 BC 95 DE EB B9 5F E7 4E C7 98 F9 50 20 AD C4 E8 7E 46 54 7A 7E
RX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8B 2B DD EE C8 28 B0 22 0B A9 BC 95 DE EB B9 5F E7 4E C7 98 F9 50 20 AD C4 E8 7E 46 54 7A 7E 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 39 30 38 33 34 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 06 08 C2 BA A9 6F CE B5 F4 85 EB B9 E5 CE D5 34 09 2E DF EF 67 26 11 FE BC E9 D6 EF 7D 79 7E
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8B 2C 05 28 60 2F 26 91 9E DD 8F 32 33 64 35 A8 D3 A0 FF 64 04 D2 27 67 BF 90 A7 80 B3 46 B1 45 0B 46 A8 A5 F7 4C 09 AF CE 68 97 93 59 DC 8C 7E
RX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8B 2C 05 28 60 2F 26 91 9E DD 8F 32 33 64 35 A8 D3 A0 FF 64 04 D2 27 67 BF 90 A7 80 B3 46 B1 45 0B 46 A8 A5 F7 4C 09 AF CE 68 97 93 59 DC 8C 7E 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 06 09 A4 7B 4A 51 DF 5A B9 21 8C B1 FC 38 F0 CE E1 21 8B ED A0 0B 0B DC 8A 4A 03 72 C8 B8 AD 2E 9C 19 96 FD EC 63 98 1F 7E
Writing Limitter value
TX: 7E A0 2D 03 61 54 27 A6 E6 E6 00 C9 1F 30 AC 14 8B 2E 27 0E CC A0 80 8E 5D 51 C8 25 B2 AD 60 CE 2C E7 E9 99 B7 F1 03 8D ED A6 86 74 6C A7 7E
RX: 7E A0 2D 03 61 54 27 A6 E6 E6 00 C9 1F 30 AC 14 8B 2E 27 0E CC A0 80 8E 5D 51 C8 25 B2 AD 60 CE 2C E7 E9 99 B7 F1 03 8D ED A6 86 74 6C A7 7E 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 06 0A 16 F6 F1 B4 87 A8 FA 94 26 1A C0 D9 60 99 5E E9 95 B2 7E
Could please correct me what is wrong?
This is my code snippet
gxLimiter limiter;
dlmsVARIANT var;
var_init(&var);
var_setUInt32(&var,240);
return ret;
Mohan Raj
Mohanraj
In reply to Hi Mikko, by Mohanraj
Any update on this please?
Mohan Raj
Mohanraj
FYI, we are able to read load limit object successfully. But write failed. not sure what is going wrong.
could you please help.
Mohan Raj
Check the limiter data type. It must be the same as monitored value.
gxLimiter limiter;
unsigned char ln[6] = { 0, 0, 17, 0, 0, 255 };
if ((ret = INIT_OBJECT(limiter, DLMS_OBJECT_TYPE_LIMITER, ln)) == 0)
var_setUInt32(&limiter.thresholdNormal, 240);
Mohanraj
Thanks for the update. but executable is getting crashed after successful write
*** stack smashing detected ***: ./bin/gurux.dlms.client.bin terminated
Aborted
Mohan Raj
Mohanraj
Below is the trace
TX: 7E A0 31 03 61 54 B2 F2 E6 E6 00 C9 23 30 AC 14 8D 6C D5 C1 6B 74 E4 FE 58 C8 36 2E 30 63 91 D2 9C A0 E0 4B 14 2C 98 5A CE 78 62 7A 38 BD F9 1C D5 5B 7E
RX: 7E A0 31 03 61 54 B2 F2 E6 E6 00 C9 23 30 AC 14 8D 6C D5 C1 6B 74 E4 FE 58 C8 36 2E 30 63 91 D2 9C A0 E0 4B 14 2C 98 5A CE 78 62 7A 38 BD F9 1C D5 5B 7E 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 07 D9 0A AC 5F BC 6A 33 B8 06 AA 63 06 63 EF 4D 24 6B 44 FC 7E
Writing success
TX: 7E A0 07 03 61 53 65 81 7E
RX: 7E A0 07 03 61 53 65 81 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
Aborted
Mohan Raj
Hi Mohan,
Hi Mohan,
We have tested this and this does not happen with our environments. Can you check all your changes?
Mohanraj
We shall check from our end
Mohan Raj
  • jebNNbevKYNMITOUy
  • KadokTen
  • xMjAupjsfUDybB…
  • GWcVnqgDuqbcJvFIAoke
  • Lewisnon
