  3. How To Write(date and Time) Single Action Scheduler Using Ansi C.
how to write(date and time) single action scheduler using ansi C.
By Mohanraj , 1 May, 2020
could please tell the process i.e what are classes to be intiated for single action scheduler?
is there a sample code for this like com_updateClock()?. please provide
Mohan Raj
6 years 3 months ago
Hi Mohan,
Hi Mohan,
You can add new execution time like described here:
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSActionSchedule
Mohanraj
In reply to Hi Mohan, by Kurumi
Thanks for the reply. I just followed the link and came up with below code snippet.
gxActionSchedule actionSchedule;
gxtime* tm;
unsigned char target[6] = { 0, 0, 10, 0, 1,255 };
const unsigned char ln[6] = { 0,0,15,0,0,255 };
cosem_init2((gxObject*)&actionSchedule, DLMS_OBJECT_TYPE_ACTION_SCHEDULE, ln);
memcpy(&actionSchedule.executedScriptLogicalName[0], target, 6);
actionSchedule.executedScriptSelector = 1;
actionSchedule.type = DLMS_SINGLE_ACTION_SCHEDULE_TYPE1;
tm = (gxtime*)malloc(sizeof(gxtime));
time_now(tm);
arr_push(&actionSchedule.executionTime, tm);
ret = com_write(connection, &actionSchedule.base, 4);
return ret;
But it throws "Access Error : Device reports a inconsistent Class or Object."
here is the trace
./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 48 -s 1 -a High -P "0000000001035820" -C "AuthenticationEncryption" -g "0.0.0.1.0.255:2" -v "0.0.43.1.3.255" -t "Verbose" -I
updateInvocationCounter
RX: FF F0 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: FF F0 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 30 00 07 B2 6C 7E
TX: 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 81 00 01 00 00 2B 01 03 FF 02 00 B5 67 7E
RX: FF F0 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 81 00 06 AC 14 8C 3A 33 B7 7E
Invocation counter: -1407939525 (0xFFFFFFFFAC148C3B)
InitializeConnection
TX: 7E A0 07 03 61 93 69 47 7E
RX: FF F0 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 AC 14 8C 3B C5 6E 6C EC C5 D0 5C E9 54 96 D6 72 FC 2A 46 07 FF 49 E6 F6 C4 58 32 90 A4 64 0A 68 7E
RX: FF F0 7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 4C 4E 54 39 30 38 33 34 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 61 62 63 64 65 66 67 68 69 6A 6B 6C 6D 6E 6F 70 BE 23 04 21 28 1F 30 00 00 06 F8 47 2D 3C A8 A7 72 2C 44 10 6C E1 17 D7 8E A5 26 02 6D 61 45 F3 A8 D0 DA 9C BC 77 AA 7E
TX: 7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 AC 14 8C 3C BF 96 83 ED 87 38 E1 99 53 52 04 F8 08 BB ED 28 D2 45 B2 CE 61 94 D9 05 FE F1 43 03 18 83 7B 67 84 BB 96 27 E9 CB 14 D3 12 40 AF 40 BB 7E
RX: FF F0 7E A0 37 61 03 52 0E 3A E6 E7 00 CF 29 30 00 00 06 F9 1C C6 63 C9 14 B3 35 7C EB 98 C7 60 E7 F6 6A 98 86 0A 47 5F E4 6E 6F A1 A3 33 4B B5 93 53 30 27 B9 70 47 91 A9 43 7E
Writing action scheduler
TX: 7E A0 3D 03 61 54 86 65 E6 E6 00 C9 2F 30 AC 14 8C 3E D8 74 CA B7 83 C8 0A 97 B8 1F D5 26 39 68 17 EB 3E 85 50 3D CA 6C 21 AC D7 EE F1 5D 97 58 94 24 DB E4 AB E1 7F 85 94 32 E0 BF 7D 98 7E
RX: FF F0 7E A0 23 61 03 74 77 CF E6 E7 00 CD 15 30 00 00 06 FA F8 A4 7A 1B 08 A7 FA EE 66 21 40 32 75 5E A1 36 57 39 7E
Write failed ActionSchedule 00.00.15.00.00.255:4 Access Error : Device reports a inconsistent Class or Object.
Please correct what is going wrong.
Mohan Raj
Hi Mohan,
Hi Mohan,
Can you try to read this action schedule first? Is that succeeded?
Mohanraj
Yes am able to read successfully. from that only we have found script logical name of it.
Mohan Raj
Mohanraj
In reply to Hi Mikko, by Mohanraj
with below commands we are able to read
./bin/gurux.dlms.client.bin -S /dev/ttyUSB0 -c 48 -s 1 -a High -P "0000000001035820" -C "AuthenticationEncryption" -g "0.0.15.0.0.255:4" -v "0.0.43.1.3.255" -t "Verbose" -I
below is the trace
-------- Reading Object ActionSchedule 00.00.15.00.00.255
TX: 7E A0 2C 03 61 BE C8 F2 E6 E6 00 C8 1E 30 AC 14 8C 7E 8D F6 6C ED 8C C2 F2 7A 37 DC 13 54 43 3B 5B 15 76 F1 D8 7A 8B FE 5F DA 28 3E F6 7E
RX: 7E A0 2C 03 61 BE C8 F2 E6 E6 00 C8 1E 30 AC 14 8C 7E 8D F6 6C ED 8C C2 F2 7A 37 DC 13 54 43 3B 5B 15 76 F1 D8 7A 8B FE 5F DA 28 3E F6 7E 7E A0 34 61 03 1A 8F D1 E6 E7 00 CC 26 30 00 00 07 1D 1F 48 A2 17 A8 45 29 67 02 C7 21 B9 0A A5 A8 81 F4 C7 1E 63 60 39 10 97 71 09 3F 6D 59 14 76 13 F8 0C 8A 7E
Index: 2 Value: 00.00.00.00.00.00 0
Index: 3 Value: 0
Index: 4 Value: [/01 00:00:00]
TX: 7E A0 07 03 61 53 65 81 7E
RX: 7E A0 07 03 61 53 65 81 7E 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
Mohan Raj
Try to change time_now(tm);
to
time_init(tm, -1, -1, 1, 0, 0, 0, 0, 0);
If it fails, can you do this without ciphering?
Mohanraj
Thanks for the update. its working now.
Mohan Raj
Thank you for the info. Meter can't handle date-time that you try to give and returns an error because of that.
  • jebNNbevKYNMITOUy
  • KadokTen
  • xMjAupjsfUDybB…
  • GWcVnqgDuqbcJvFIAoke
  • Lewisnon
