  3. Client Address Value
By Bhaumik , 17 January, 2020
When I change the manufacturer from GXDLMSDirector, The value of the authentication level and Client address were updated.
The client address value is different for the respective manufacturer.
How the client address value will be calculated over there?
6 years 9 months ago
Hi Bhaumik,
Hi Bhaumik,
Client and server addresses are depending on the manufacturer.
They are defined in DLMS standard and new meters are usually using same values,
but with older meters values can be anything.
Client addresses are defined in the settings file when you create a new manufacturer.
