  3. ServiceError Initiate Error Exception.Initiate Other
ServiceError Initiate Error Exception.Initiate other
By Varun Sharma , 12 December, 2019
Why this error comes everytime.I have to switch off the meter to download it again.
6 years 9 months ago
The amount of the error codes is very small in DLMS. This might mean anything, BUT if you have to switch off the meter you need to contact the meter manufacturer and ask them to fix this.
The meter must handle even you send "Hello World" and recover from it.
Varun Sharma
this error always comes in
this error always comes in Client.ParseAAREResponse(reply.Data) method but with kalkitech meter works fine everytime
10 : 16 : 11 METER-1 SENDING HDLC FRAME
10 : 16 : 11 ====>Tx METER-1 7E A0 07 03 21 93 0F 01 7E
10 : 16 : 11 METER-1 RECEIVED HDLC FRAME
10 : 16 : 11 <====Rx METER-1 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
10 : 16 : 11 METER-1 COSEM OUT DATA
10 : 16 : 11 ====>Tx METER-1 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 18 1D FF FF
10 : 16 : 11 METER-1 SERVICE = AARQ
10 : 16 : 11 ====>Tx METER-1 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 18 1D
FF FF 5F AF 7E
10 : 16 : 11 <====Rx METER-1 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E
08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 1C EA 7E
10 : 16 : 11 METER-1 RECEIVED APPLICATION LAYER FRAME
10 : 16 : 11 <====Rx METER-1 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02
00 00 07
10 : 16 : 11 METER-1 SERVICE = AARE
10 : 16 : 11 ====>Tx METER-1 7E A0 07 03 21 53 03 C7 7E
this is the kalki log and below is Gxdlms director
10:30:16 Initializing serial connection.
10:30:17 AM Send SNRM request.
10:30:17 AM
10:30:17 Parsing UA reply succeeded.
10:30:17 AM Send AARQ request.
7E A0 57 03 21 10 8A 62 E6 E6 00 60 49 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 00 BE 23 04 21 21 1F 30 00 00 00 3C 20 32 AD D8 F6 53 66 F5 12 28 1D F3 DF 35 B2 B6 A6 8D 4D 97 A1 20 68 B9 A8 E0 8F E7 7E
10:30:17 AM
7E A0 25 21 03 30 BB 86 E6 E7 00 61 1E A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D E8 DE 7E
10:30:17 Disconnect request
10:30:17 AM
You try to use ciphered connection with GXDLMSDirector. Set Security to None from "Secured connections" tab.
  • govendd
  • ratan1209
  • avadhesh.p
  • Peter Mudenda
  • Sudhanshu Yadav
