  3. Insufficient Memory
Insufficient memory
By utkarsh , 14 November, 2019
I am new to DLMS meter. I have taken gurux.dlms.server.example2.java as meter and DLMS Director as client.
I am trying to connect meter in secure mode with settings as shown in attached screenshot. But I am getting below error.
23:20:32
<WRAPPER len="67" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="7177657274797569" />
<MechanismName Value="High" />
<CallingAuthentication Value="51580D4A782852052A2509241F032845" />
<glo_InitiateRequest Value="3000000000F20CD2063D2249B7339079AA79315529A372CA2AAB1DC10B2496" />
</AssociationRequest>
</PDU>
</WRAPPER>
23:20:37
<HDLC len="20" >
<!--S frame.-->
<!--Invalid I Frame: 97. Expected: 0-->
<FrameType Value="97" />
<PDU>
Insufficient memory to continue the execution of the program.
23:20:42
<HDLC len="20" >
<!--S frame.-->
<PDU>
23:20:42
<HDLC len="20" >
<!--S frame.-->
<PDU>
Logs:
GXDLMSDirector 8.2.1910.3102
Log created 11:20:27 PM
23:20:31 Initializing Network connection.
11:20:32 PM Send AARQ request.
00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 51 58 0D 4A 78 28 52 05 2A 25 09 24 1F 03 28 45 BE 23 04 21 21 1F 30 00 00 00 00 F2 0C D2 06 3D 22 49 B7 33 90 79 AA 79 31 55 29 A3 72 CA 2A AB 1D C1 0B 24 96
11:20:37 PM Data send failed. Try to resend 1/3
11:20:42 PM Data send failed. Try to resend 2/3
11:20:47 PM Data send failed. Try to resend 3/3
11:20:52 PM Failed to receive reply from the device in given time.
7E A0 21 61 03 97 94 23 61 00 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A2 03 02 01 25 BE 7E 7E A0 21 61 03 97 94 23 61 00 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A2 03 02 01 25 BE 7E 7E A0 21 61 03 97 94 23 61 00 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A2 03 02 01 25 BE 7E 7E A0 21 61 03 97 94 23 61 00 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A2 03 02 01 25 BE 7E
11:20:52 PM
6 years 10 months ago
From the trace, it looks like you have select WRAPPER as an interface type, but the meter is using HDLC.
Try to change WRAPPER to HDLC. It's interesting that meter is answering at all.
utkarsh
Thanks for you prompt reply.
Thanks for you prompt reply. I want meter to be WRAPPER as an interface type. Please let me know the place to configure this in guru.dlms.server.example2.java codebase.
Set the interface type to wrapper after you have set meter settings.
utkarsh
Meter is listening at 4063.
Meter is listening at 4063. And I see code is
GXDLMSServerLN_47.java
super(new GXDLMSAssociationLogicalName(), InterfaceType.WRAPPER);
Yes, that is correct.
utkarsh
Director has interface as
Director has interface as WRAPPER and meter is also having interface as WRAPPER. Then what is the issue ?
Data what meter is returning is using HDLC framing, not WRAPPER.
utkarsh
I have not change any code
I have not change any code meter side from the example server 2. Is it issue with DLMS library ?
I enabled the tracing at meter side. below is the trace.
Client Connected.
<- 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 6E 72 67 74 3C 02 47 2B 2F 40 32 21 25 0F 1E 02 BE 23 04 21 21 1F 30 00 00 00 00 F2 0C D2 06 3D 22 49 B7 33 90 79 AA 79 31 55 29 A3 72 CA 2A AB 1D C1 0B 24 96 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 6E 72 67 74 3C 02 47 2B 2F 40 32 21 25 0F 1E 02 BE 23 04 21 21 1F 30 00 00 00 00 F2 0C D2 06 3D 22 49 B7 33 90 79 AA 79 31 55 29 A3 72 CA 2A AB 1D C1 0B 24 96 00 01 00 30 00 01 00 5F 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 71 77 65 72 74 79 75 69 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 6E 72 67 74 3C 02 47 2B 2F 40 32 21 25 0F 1E 02 BE 23 04 21 21 1F 30 00 00 00 00 F2 0C D2 06 3D 22 49 B7 33 90 79 AA 79 31 55 29 A3 72 CA 2A AB 1D C1 0B 24 96
Data length is 95and there are 301 bytes.
-> 7E A0 21 61 03 97 94 23 61 00 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A2 03 02 01 25 BE 7E
Client Disconnected.
I tested this by my self. I started gurux.dlms.server.example2 project. Then I selected "Indian Standard" to meter manufacturer and changed Interface from HDLC to WRAPPER. Then I set correct TCP/IP address and port number to 4063. Meter reply as expected.
Check that you have not made any changes to the source code. Nobody else has this problem.
utkarsh
6 years 9 months ago
I checked it again. Issue is occurring when security is set to "AuthenticaionEncryption". I have set SystemTile
BlockCipherKey
Authentication Key
as well.
Can you pls share your Security settings if it is working fine.
Utkarsh
