  3. Sagem Cx2000-9
Sagem Cx2000-9
By caners , 20 September, 2019
Hi, I am trying to connect Sagem CX2000-9 meters through optical port, serial. Is there any inital settings dedicated to this meter. Thanks in advance
Caner
6 years 12 months ago
Hi Caner,
Hi Caner,
No at the moment. Select Landis+Gyr as the manufacturer and try.
If it fails, try to change the baud rate.
caners
I have tried Landis+Gyr with different baud rate. It doesn't work. Thank you for your prompt reply.
BR / Caner
Hi Caner,
Hi Caner,
We don't have Sagem CX2000-9 on the office so I can't verify this.
Can you ask from the meter vendor if they know is optical probe using MBUS or DLMS.
Some meters don't support DLMS when communicating with an optical probe.
Hi Caner,
Hi Caner,
caners
Thank you, I will update you
Thank you, I will update you when I will have reply from the manufacturer
