  3. Protocol Converters
Protocol converters
By Thijs , 25 February, 2019
Hey,
I want to implement a device on the optical port to communicate with the smart meter. i want to use gurux to communicate by HDLC with the smartmeter. And use the device to communicate to the existing DLMS/COSEM-TCP-IP connection. So in order to get this working a need a protocol translator from DLMS/COSEM-TCP-IP to DLMS/COSEM-HDLC
and then in reversed order DLMS/COSEM-HDLC to DLMS/COSEM-TCP-IP.
So my question about this is:
is there already something like this implemented?
If not can you point me to a good point to start with?
7 years 8 months ago
You did not say what programming language you want to use.
You can get source codes from GitHub.
https://github.com/gurux/
  • Anand Raj
  • amir.jradi
  • JOEBID€N123
  • yogibear
  • Eric@li
