  3. Decryption of Notification Data
By Sajjad khan pathan , 15 January, 2019
Hey,
Is it possible to decrypt the data received in Notification window with authenticated encryption ?
7 years 6 months ago
If your keys are correct decrypted data should be shown if you have selected "Pdu" and "Comments" from "View" | "Notifications"
Sajjad khan pathan
In reply to Decryption of Notification Data by Kurumi
Yes, I've selected pdu and comments in Notification view but its showing Encrypted Data.
Issues may be something like if i have added multiple devices and they may have different keys, different target address, which one is used for decryption ?
i tried to decrypt data with source code but the result was not as intended.
here is what i tried :
public void DecryptData()
try
client.ClientAddress = 30;
client.Authentication = Authentication.HighGMAC;
client.Ciphering.BlockCipherKey = GXCommon.HexToBytes("Some key");
client.Ciphering.AuthenticationKey = GXCommon.HexToBytes("Some key");
client.Ciphering.DedicatedKey = GXCommon.HexToBytes("Some key");
client.Ciphering.SystemTitle = GXCommon.HexToBytes("Title");
client.Ciphering.Security = Security.AuthenticationEncryption;
client.UseLogicalNameReferencing = true;
int logicaladdress = Convert.ToInt32("0");
int physicaladdressint = Convert.ToInt32(1);
client.ServerAddress = GetServerAddress(logicaladdress, physicaladdressint, 1);
client.ServerAddressSize = (byte)1;
GXByteBuffer ciphertext = new GXByteBuffer();
ciphertext.Set(GXCommon.HexToBytes("D482001E3000000935ECD4CADA3280D3628ADBF6AE4CCCC2B54A33B9299F637B0C80"));
uint IC = 2357;
AesGcmParameter p = new AesGcmParameter((byte)Command.DedGetResponse, client.Ciphering.Security, IC, client.Ciphering.SystemTitle, client.Ciphering.BlockCipherKey, client.Ciphering.AuthenticationKey);
GXByteBuffer data2 = new GXByteBuffer();
byte[] data3 = GXDLMSChippering.DecryptAesGcm(p, ciphertext);
data2.Set(data3);
string Result = data2.ToString();
MessageBox.Show(Convert.ToString(Result));
catch (Exception ex)
MessageBox.Show(ex.Message);
reply.Clear();
Can you suggest ?
Do you have problems if you have only one meter? If you have several meters it might cause problems to translator.
Sajjad khan pathan
Yes, the problem is there when i have only one meter.
This is what i receive.
May be i am doing something wrong ? Or the meter is sending something which you do not expect ?
Data downloading and other communication is all OK.
As the trace and Log data are also received in the same way.. so i was supposing the GXDLMSDirector doesn't decrypt these data before showing.
01/15/2019 3:57:46 PM
<GeneralGloCiphering>
<SystemTitle Value="474F4500007BE512" />
<CipheredService Value="3000000001B3C3A79A2F3EDD38364345044F3F5B295840F9DDC23AA4DDA70CF57C3AD6F75F5601940C5C90A7768AFDFEB9405C0B666B18BB1CF5DCAABA3A39DF4F0EB87C79E27C50FD1E22078D160F06417000736A4925779630FFFC271F6D2D4B789B03D6C14E746C3CA550FEEE90F239E150B1EF54F77A025E9A43A7DE3C65C0" />
</GeneralGloCiphering>
Client disconnected: 10.78.163.40:38042
Sajjad khan pathan
In reply to Decryption of Notification Data by Sajjad khan pathan
Let me add the source code of Notification window from GXDLMSDirector,
try
//Show as PDU.
eventsTranslator.PduOnly = NotificationPdu.Checked;
eventsData.Set((byte[])e.Data);
GXByteBuffer pdu = new GXByteBuffer();
InterfaceType type = GXDLMSTranslator.GetDlmsFraming(eventsData);
StringBuilder sb = new StringBuilder();
while (eventsTranslator.FindNextFrame(eventsData, pdu, type))
sb.Append(eventsTranslator.MessageToXml(eventsData));
pdu.Clear();
if (AutoReset.Checked)
EventsView.ResetText();
if (NotificationTimeMnu.Checked)
OnAddNotification(DateTime.Now.ToString() + Environment.NewLine + sb.ToString());
else
OnAddNotification(sb.ToString());
eventsData.Clear();
OnAddNotification(ex.Message);
I don't this only the translator will Decrypt the AES-128 Authenticated Encrypted Data ?
Data is tried to decrypt and it's shown if it succeeds on the Notify log. We'll check this and let you know later this week.
Sajjad khan pathan
Ok,
Thanks for the response !
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
  • highclassrightway
  • sapran
