  3. DateTimeOffset Is Not Korrekt On Summer/winter Time Change
DateTimeOffset is not korrekt on summer/winter time change
By Stier , 20 January, 2017
Hey guys,
I actually implementing the latest Gurux.DLMS version (8.5.1612.2006). So far I just identified one problem with this version and I'm able to workaround this easily.
But I just wanna inform you of this problem, so you may fix it once.
The GXDateTime.Value Property contains a System.DateTimeOffset which is great compared to older versions that only provided a System.DateTime. The problem seams to be on the winter/summer change. I wrote a small Console Application to give you an example of the problem:
This is just a readout (load profile 1, Obis: 1.0.99.1.0.255) of an L+G E650 over the time change:
(Just time column splitted up in DateTimeOffset and State)
30.10.2016 00:00:00 +02:00 DaylightSavingActive
30.10.2016 00:15:00 +02:00 DaylightSavingActive
30.10.2016 00:30:00 +02:00 DaylightSavingActive
30.10.2016 00:45:00 +02:00 DaylightSavingActive
30.10.2016 01:00:00 +02:00 DaylightSavingActive
30.10.2016 01:15:00 +02:00 DaylightSavingActive
30.10.2016 01:30:00 +02:00 DaylightSavingActive
30.10.2016 01:45:00 +02:00 DaylightSavingActive
30.10.2016 02:00:00 +01:00 DaylightSavingActive
30.10.2016 02:15:00 +01:00 DaylightSavingActive
30.10.2016 02:30:00 +01:00 DaylightSavingActive
30.10.2016 02:45:00 +01:00 DaylightSavingActive
30.10.2016 03:00:00 +01:00 DaylightSavingActive
30.10.2016 02:00:00 +01:00 Ok
30.10.2016 02:15:00 +01:00 Ok
30.10.2016 02:30:00 +01:00 Ok
30.10.2016 02:45:00 +01:00 Ok
30.10.2016 03:00:00 +01:00 Ok
30.10.2016 03:15:00 +01:00 Ok
30.10.2016 03:30:00 +01:00 Ok
30.10.2016 03:45:00 +01:00 Ok
30.10.2016 04:00:00 +01:00 Ok
As you can see the first block (summertime) from 2-3 o'clock is handled with an offset of +01:00, but the state of the value is set to "DaylightSavingActive", so the offset should be +02:00, or am I wrong?. Second block (wintertime) is okay.
Thanks for your investigation.
Best regards,
Andrea
9 years 6 months ago
DateTimeOffset
This date time is really bad in DLMS. Standard says that date time is range -720…+720 in minutes of local time to UTC. So example here in Finland meter SHOULD be configure -2 hours. Out time zone is UTC +2 h.
We actually broke this some time ago. We have clients who have configure meters using UTC time. We fixed this back to this version.
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
