Dear GuruX;
Hello, I am Hasha, From Mongolia. First of all, Thanks for this great project. I have to read Holley DTSD545 data via DLMS and I have faced problem. Please help me for this. Also, I attached error pic and log pic.
thank you :)
Meter returns error. Can you use Low authentication level to make connection?
One possibility is that association view is not implemented. In that case you need to know OBIS codes.
Can you verify this from the vendor?
Would you please send me your Gurux GXDLMSDirector file ( .gxc) that you used to communicate with the DTSD545 meter. One of my research assistants is working on a similar experiment for Holley meters. Please email to Prof.Abdelati@gmail.com
I added support for Holley Metering Ltd.
Restart GXDLMSDIrector and it will notify that there are new settings available.
Download them and you have support for Holley meters.
Please, let me know if you have any questions.
I try to to read Holley DTSD545 data via DLMS and I have the same error with that meter. I use the latest version of GXDLMSDIrector 8.2.
Did anything changed in the application? Or perhaps I did something wrong?
Hi hasha,
Does current version of GXDLMSDirector work with your DTSD545?
Could you check it, please?
Because I also have a DTSD545 meter, but GXDLMSDirector doesn't exchange properly.
Holley DTSD545 calling objects failed
Hi Hasha,
Please, send trace as text. It's easier to read.
Dear Mikko,
Dear Mikko,
Okay, I am sending to you log file and initialize settings pic. Also Holley send to me their OBIS.
10:59:58 AM Initializing serial connection.
10:59:58 AM 10:59:58.306 Info Opening
10:59:58 AM 10:59:58.306 Info Serial Port Settings: Port Name: COM6 Baud Rate: 9600 Data Bits: 8 Parity: None Stop Bits: One Eop: None
10:59:58 AM 10:59:58.868 Info Open
10:59:58 AM Send SNRM request.
7E A0 07 03 21 93 0F 01 7E
10:59:58 AM 10:59:58.869 Sent 7E A0 07 03 21 93 0F 01 7E
10:59:58 AM 10:59:58.919 Received 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
10:59:58 AM Received data
10:59:58 AM Parsing UA reply.<CR><LF>81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01
10:59:58 AM Parsing UA reply succeeded.
10:59:58 AM Send AARQ request
7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 FE 1F FF FF F7 E5 7E
10:59:58 AM 10:59:58.920 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 FE 1F FF FF F7 E5 7E
10:59:59 AM 10:59:59.049 Received 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1C 00 F0 00 07 DE 6A 7E
10:59:59 AM Received data
10:59:59 AM Parsing AARE reply<CR><LF>61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 1C 00 F0 00 07
10:59:59 AM Parsing AARE reply succeeded.
11:00:01 AM --- Collecting objects. ---
11:00:01 AM Collecting objects
7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
11:00:01 AM 11:00:01.818 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
11:00:01 AM 11:00:01.879 Received 7E A0 11 21 03 52 B1 F8 E6 E7 00 C4 01 C1 01 04 CC F6 7E
11:00:01 AM Received data
System.Exception: GetObjects failed. Access Error : Device reports a undefined object.
at GXDLMSDirector.MainForm.ReadDevice(GXDLMSDevice dev)
at GXDLMSDirector.MainForm.Read(Control sender, Object[] parameters)
11:00:02 AM Disconnect request
Hi hasha,
Hi hasha,
Holley Metering Ltd
DTSD545
Thank you Mikko for including Holley Metering Ltd within the manufacturers list. Every thing is perfect.
M. Abdelati
DTSD545
Dear M. Abdelati,
Thank you from this information. Please, let me know if you have something.
GXDLMSDirector 8.2.1906.1301
Log created 20:21:54
20:22:03 Initializing Network connection.
20:22:03 08:22:03.575 Info Opening
20:22:03 08:22:03.575 Info Client Settings: Protocol Tcp Host: 192.168.43.21 Port: 8990
20:22:04 Send SNRM request.
7E A0 07 03 23 93 BF 32 7E
20:22:04 08:22:04.183 Sent 7E A0 07 03 23 93 BF 32 7E
20:22:05 08:22:05.000 Received 7E A0 1E 23 03 73 7B CF 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
20:22:05
20:22:05 Parsing UA reply succeeded.
20:22:05 Send AARQ request.
7E A0 44 03 23 10 56 B7 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 5C FD 7E
20:22:05 08:22:05.000 Sent 7E A0 44 03 23 10 56 B7 E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 30 30 30 30 30 30 30 30 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 5C FD 7E
20:22:06 08:22:06.197 Received 7E A0 37 23 03 30 D4 C9 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 00 F0 00 07 C2 40 7E
20:22:06
20:22:06 Parsing AARE reply succeeded.
20:22:07 --- Collecting objects. ---
20:22:07 Collecting objects
7E A0 19 03 23 32 DF EB E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
20:22:07 08:22:07.641 Sent 7E A0 19 03 23 32 DF EB E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
20:22:08 08:22:08.458 Received 7E A0 11 23 03 52 09 4D E6 E7 00 C4 01 C1 01 04 CC F6 7E
20:22:08
at GXDLMSDirector.MainForm.RefreshDevice(GXDLMSMeter dev, Boolean bRefresh)
at GXDLMSDirector.MainForm.Refresh(Object sender, GXAsyncWork work, Object[] parameters)
Hi hasha,
Hi hasha,
