  3. Unable To Write The Disconnect Control Object
Unable to write the disconnect control object
By kishore kumar k , 2 August, 2016
I am trying to read/write electric parameters from a DLMS device (meter).
I am able to read the Disconnect Control (Class ID 70 ), which is set to Mode 3.
However, when tried to write it to activate the disconnect feature , I am unable to do it.
(There is no edit field present in it to activate the feature)
Can you let me know the procedure or the way to enable this feature.
  • 7095384824
  • koltom
  • palso
  • VigneshwaranC1993
  • Yousef Al-Saye…
