  3. Connecting a Landis+Gyr Data Concentrator With GuruxDirector
Connecting a Landis+Gyr Data concentrator with GuruxDirector
By Ramkrishna , 7 June, 2016
I am trying to connect GuruxDirector with Landis+Gyr DC450 Data Concentrator and read data from several meters. May I know whether it is possible with the GuruxDirector or not? I have tried to connect, but the Data Concentrator is rejecting the connection.
Thank you in advance for your help :)
10 years 4 months ago
You should be able to connect if you use serial number as meter address.
Lucas
8 years 9 months ago
Hi Ramkrishna
Did you management to connect to the DC450?
I have a similar alternative currently, but I don't want to go to the expense if it doesn't work.
lugaflo
6 years 12 months ago
Dears,
Dears,
We plan to connect to a E450 from Landis&Gyr via a DC250 concentrator using the DLMSDirector.
Do we need to set the Serial number in the Physical device address field from Gateway menu ? (see attached picture).
thx,
Florent
6 years 10 months ago
In reply to Dears, by lugaflo
