  3. IPv6 and UDP Support
IPv6 and UDP support
By coppice , 14 April, 2016
If I use DLMSDirector 8.0.0.16 to connect to a meter using an IPv4 or IPv6 address by TCP my meter gets a connection, and I can communicate OK. If I try to connect to a meter using an IPv4 address by UDP, DLMSDIrector sends to the meter OK. However, if I try to connect to a meter using an IPv6 address by UDP, I get an error box saying "An address incompatible with the requested protocol was used bbbb::102:4059. I specified the address as "[bbbb::102]" in the dialogue box.
Administrator
10 years 3 months ago
I made issue from this: http://www.gurux.fi/node/5080
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
  • SunbetLith
