By dops, 26 May, 2015
Hi, i'm dops and this is my first post here. Good day to all! :)
I hope you can help me. I try to connect to an itron gas meter Gallus sV G https://www.itron.com/local/Italy%20Product%20Portfolio/GALLUS%20SVG%20…
throgh an optical prob that you can see here: https://www.probeformeters.com/brochure/brochure_kmk116_en.pdf
Gas meter seems support dlms protocol so i try to connect with your Gurux DLMSDirector software. I try changing some bound rate.. but nothing.. all i receive is an message like timeout because no jet a reply in time.
I think have selected the roght option ( Actaris gas meter annd so other).
Can you help me about? ;)
Hi, first, really really sorry for delay, but i never received a notification about your reply and so i never seeing.
So, yes i can make my application, or you can make for me, this depend.. if you are again interested, you can send me a pvt message / email about. Maybe i try to send you an email with my most good email address.
But, sorry, a question: why i can't use gurux dlms director software if it, as reported here http://gurux.fi/GXDLMSDirector, support IEC 62056-21?
I hope in your quickly reply and see every day this post because notification not work.. :)
I'll send Private message to you today. GXDLMSDirector is using IEC 62056-21 in Mode E. Your meter is working on mode C. Mode E is binary mode and mode C is ASCII mode.
So we are using IEC 62056-21, to start using DLMS/COSEM, but your meter supports only ASCII mode. Reading meters is not always so easy. :-)
connect to gas meter with optical probe
I finally received some information from your meter.
Your meter is not supportting DLMS/COSEM.
It is supporting IEC 62056-21.
You must do your application by your self or we can do it for you.
Let me know if you are interested.
sorry for delay
Thanx
I understand. I really need
I understand. I really need help about. Haven't so feeling with meter programming. I ho in a your pvt message asap. ;)
