  3. Settings For Configuring GuruxDLMS Director With Indian Standards
Settings for configuring GuruxDLMS Director with Indian standards
By shabin shanavas , 14 March, 2025
Can you please help me to configure the appropriate settings for connecting L&T EP300R Watthour meter with GuruxDLMS Director for reading the 3 phase voltage, current, energy from it. We have connected the meter to PC over rj45 cable with rs232 converter. What would be the next steps that we should do in the GuruxDLMS Director?
Kindly reply
Best Regards,
Shabin
1 year 8 months ago
Hi, Select "Indian standard"…
Select "Indian standard" as a manufacturer, select HDLC as the interface and make the connection.
shabin shanavas
1 year 8 months ago
Hi Mikko, We have connected…
We have connected the meter successfully. At the current window there is only some basic things like manufacture ID, clock etc.. What should I do to get the current, voltage, energy etc.. parameters?
Best regards
Shabin
1 year 8 months ago
Hi, You need to establish…
You need to establish the connection to the meter before you can read anything from the meter. I propose that you play with GXDLMSDirector. It will help you to understand DLMS meters.
shabin shanavas
1 year 8 months ago
Hi Mikko, I have added the…
I have added the Object for Power Factor (1.0.33.7.0.255) in Extended Register. But it only returns value for one time once the connection is established. What will be the possible issue?
Kindly reply.
Best Regards,
shabin
1 year 8 months ago
Hi, Values are saved to the…
Values are saved to the database. Value is read every time you press the read button.
You can use the scheduler to do value reading periodically.
