  3. Event Status Word 1 (ESW-1) 0.0.94.91.18.255
By vivek604 , 18 January, 2025
Need to provide copy option for Event Status Word 1 (ESW-1) 0.0.94.91.18.255, Currently only view option available , some time manufacturer bit goes high in this case need to save the data
1 year 10 months ago
Hi, You can copy the Event…
You can copy the Event Status Word if you select the textbox and select "Ctl+C" or right-click the mouse and select "Copy".
vivek604
1 year 9 months ago
As per your reply there is…
As per your reply there is no option to select the textbox for Event Status Word 0.0.94.91.18.255. Text box option is available for ESWF 0.0.94.91.26.255
1 year 9 months ago
Hi, Is 0.0.94.91.18.255 data…
Is 0.0.94.91.18.255 data object or profile generic in your meter?
vivek604
1 year 9 months ago
0.0.94.91.18.255 is data…
0.0.94.91.18.255 is data object.
1 year 9 months ago
Hi, Are you seeing Event…
Are you seeing Event Status word (0.0.94.91.18.255.) as a selection list and not as a textbox?
vivek604
1 year 9 months ago
Unable to understand your…
Unable to understand your point . My concern is that Event Status Word data which is 128 bit showing without text box, unable to copy all 128 bit .
1 year 9 months ago
Hi, You can select all text…
You can select all text in the text box if you double-click the text box and then select copy from the popup menu.
vivek604
1 year 9 months ago
Kindly share mail id. I hope…
Kindly share mail id. I hope you are not unable to understand my point.
1 year 9 months ago
Hi, The bitstring is in the…
The bitstring is in the textbox below the value table. Select that bitstring and you can copy it as I advise.
