  3. Push Setup View Error
Push setup view error
By andre538 , 15 January, 2025
Hello Mikko,
I'v got error window (one word only - "Index") while trying to view PushSetup.
A little bit investigation in source code shows that OnValueChanged and OnAccessRightsChange in GXDLMSPushSetupView.cs cycle through arg.Index from 2 to 4 only, throwin an exception for anything else.
At the same moment, data received from meter contains total 13 attribute index fields, as described in blue book 4.4.8.2 push setup class id 40, version 2 description.
So it seems Push setup IC description extended some time ago.
1 year 10 months ago
Hi, You are right. The…
You are right. The current version from GXDLMSDirector supports only version 0. I'll add this to the worklist. The next version will be released this month.
artsiom_a
1 year 7 months ago
Hi Mikko, I wonder if there…
I wonder if there are any updates on the issue?
Best regards,
Artsiom.
