  3. RTC Fomating Issue
RTC fomating issue
By vivek604 , 20 December, 2024
Facing issue with gx director 9.0.2412.1801 RTC format differ than my PC RTC.
1 year 11 months ago
Hi, Can you describe the…
Can you describe the problem a little bit more? The format of the clock is read from the PC.
vivek604
1 year 10 months ago
MY Laptop RTC format (DD-MM…
MY Laptop RTC format (DD-MM-YYYY) but gurux is showing in (MM-DD-YYYY) format due to this unable to perform RTC related settings(Single action , Push scheduling....) in the meter through GURUX. This issue observed with director 9.0.2412.1801
Hi, I believe that you are…
I believe that you are using .Net framework 4.8 and Microsoft is doesn't support it anymore. Get the latest version from GXDLMSDirector and let me know if you still have probelems.
vivek604
After install new version 9…
After install new version 9.0.2412.3101 RTC format related issue resolved. Thanks.
