  3. Difference Between Map110 Nad GXDLM
Difference between Map110 nad GXDLM
By RSAAlanNewham , 18 October, 2024
Good day.
If i read the profile data with Map110 the Registers will show
1-1:1:5.0 (kW)
1-1:5:5.0 (kvar)
1-1:9:5.0 (kVA)
However when I read the same profile data with GXDLM I will get
1.1:1:4.0 (kW)
1.1:5:4.0 (kvar)
1.1:9:4.0 (kVA)
The data is the same for both, but the OBIS code is different.
The meter is set up with addresses as I see them in the Map110 Software.
I'm just trying to understand why it changes the register in the GXDLM software?
2 years ago
Hi, GXDLMSDirector shows the…
GXDLMSDirector shows the OBIS code that is read from the meter and doesn't change it anyway. I believe that Map110 increases the value for some reason.
