  3. Wasion AMeter100 Default Settings
Wasion aMeter100 default settings
By flagr97 , 26 August, 2024
Hi Mikko, in this topic: https://www.gurux.fi/forum/16758 you mentioned that Wasion aMeter100 is compatible, I have a unit here but I tried several addresses/configs and didn't have any luck on trying to connect to it. Can you share what settings this meter uses for default? Thanks
2 years 2 months ago
Hi, If you are using an…
If you are using an optical probe, change the interface type to WhlcWithModeE.
If you are using a serial port connection, check your baud rate.
