  3. Lzqj With Rs232 Serial
lzqj with rs232 serial
By igotar , 12 June, 2024
Hi, please, can anyone help me query the 1.8.0 register directly via the serial cable of my PC, this counter? I use a program directly in VBnet opened on COM3. Thanks
2 years 5 months ago
Hi, Try to connect first…
Try to connect first with GXDLMSDirector. Select "EMH Metering" as a manufacturer and select the correct serial port.
You can see the correct parameters when you connect with GXDLMSDirector.
Try to change the baud rate If the meter doesn't reply.
igotar
Thank you
Thank you
igotar
I can't communicate via…
I can't communicate via serial port.help
igotar
setting
setting
Hi, I believe that the…
I believe that the reason is baud rate. It' something else than 9600. Our customers are usually reading EMH with TCP/IP and I can't remember the EMH default baud rate at the moment, but try e.g. 4800.
