  3. Could Not Read IPv4 Setup Object
Could not read IPv4 Setup object
By Pavel Svihalek , 23 January, 2024
Other objects, I tried, are OK, But when I want to read IPv4 Setup object, only clearing communication log window is happening. None packet is sent. After time, I can see "Send Keep Alive" packet. The behaviour is for Com port connection and for TCP connection same.
Pavel Svihalek
2 years 10 months ago
I do not know why, but after…
I do not know why, but after removing and adding object again it is reading normally.
Hi, If you select the Access…
If you select the Access Rights tab you can see access levels. I believe that their level is None and the meter is not read.
Access levels are read when object associations are read from the meter. When you read objects again the level is read from the meter again.
