  3. Secured Connection Using Keys That Are More Than 16 Bytes Hex
Secured connection using keys that are more than 16 bytes hex
By adryan , 1 November, 2023
Hi!
I'm trying to connect to my meter to Gurux DLMS Director using secured connections. I have the system title and the keys but the keys are 24 bytes long not 16. So I couldn't enter my Auth Key and Block Cipher Key. and received error "Invalid authentication key" or "Invalid block cipher key".
Auth Key: 212DD693E9B4D075173266774F164CE9E3E1FC9FD5E00988
Block Cipher Key is same.
Is there anything I could try to connect to my meter?
Really need help for this.
Thank you.
3 years ago
Hi, DLMS standard says that…
DLMS standard says that the Block cipher and authentication keys size is 16 bytes (AES-GCM-128) for Security Suite 0 and 1. Security Suite 2 (AES-GCM-256) uses 32 bytes long keys.
Check your keys or then your meter is not a DLMS meter.
adryan
3 years ago
Hi! Thanks for the answer. I…
Hi!
Thanks for the answer. I contacted the person and told me that the key was encrypted. I got the decrypted one with 16bytes long. Everything works well now.
3 years ago
Hi, Ciphering can be hard…
Ciphering can be hard because there are so many different parameters. I'm glad that you can read your meter.
