  3. Cannot Connect Holley DDSY283
Cannot connect Holley DDSY283
By khana , 25 September, 2023
Hello
I am trying to connect Holley DDSY283 smart meter using dlms.
But it returns:
GetObject failed. Access error: Device reports a temporary failure.
3 years 1 month ago
Hi, If I remember correctly,…
If I remember correctly, all Holley meters don't support the association view, even if it's mandatory. Try to add objects manually. Select "Edit" and "Add Object". Then try to add a clock object and read it. If you can read it, you need to add all the objects manually. You need to ask for the list of objects from Holley.
khana
3 years 1 month ago
it working thank you
