  3. Connect To EMH LZQJ-XC
Connect to EMH LZQJ-XC
Profile picture for user oulahsensaid
By oulahsensaid , 12 May, 2023
Hi, Kurumi. Please could you help me again.
I'm trying many settings to connect to EMH-XC SN4445110, but the meter still sending the same error: Failed to receive reply from the device in given time.
Thank you so mutch.
Media: Optical probe.
GXDLMSDirector 9.0.2302.2001
Log created 21:34:08
Initializing serial connection.
IEC Sending:/?!<CR><LF>
HDLC received: /EMH4\@01LZQJL0026F<CR><LF>
BaudRate is : 4800
Moving to mode E.
06 32 34 32 0D 0A
Send SNRM request.
7E A0 0A 00 02 52 ED 21 93 F9 87 7E
Disconnect request
Send Disconnect request.
7E A0 0A 00 02 52 ED 21 53 F5 41 7E
à GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
oulahsensaid
3 years 6 months ago
Hi Mr. Kurumi. New log:…
Log created 14:20:48
HDLC received: 6(000002*kW)(0050621215000)<CR><LF>
System.Exception: Invalid responce.
à GXDLMSDirector.GXDLMSCommunicator.InitSerial()
HDLC received: <LF>
HDLC received: 8.0(00084846*kWh)<CR><LF>
Hi, All optical probes don't…
All optical probes don't work with EMH meters and I believe that it the problem in your case. Ask what optical probe you should use from the EMH.
Try to select "Use Maximum Baud Rate" and use 300.
In your next reply your meter is sending data using IEC protocol and not DLMS.
Thank you for your response,…
Thank you for your response, Mr, Kurumi.
That's what I was thinking.
Anyway, her is the log:
Log created 15:45:52
IEC Sending:/?4445110!<CR><LF>
Maximum BaudRate is set to : 300
BaudRate is : 300
Moving to mode E.
06 32 30 32 0D 0A
Send SNRM request.
7E A0 0A 00 00 52 ED 21 93 71 91 7E
Data send failed. Try to resend 1/2
Disconnect request
7E A0 0A 00 00 52 ED 21 53 7D 57 7E
Hi Mr. Kurumi. After getting…
Hi Mr. Kurumi.
After getting EMH optical probe, I can not connect to the meter and it send the same response (Failed to receive reply from the device in given time).
Best regadrs.
Hi, Try to change physical…
Try to change physical server address to 0x10 and logical address to zero.
oulahsensaid
3 years 5 months ago
Hi. After more than three…
Hi.
After more than three weeks, I'am not able to connect to EMH, Trying a lot of settings without any success.
Please, any suggestions or path to follow.
Bests regard.
