  3. Test Multiple Meter Using Gurux Director
Test multiple meter using Gurux director
By srikanthj , 2 May, 2023
Hello Team,
Gurux director tool to energy meter we are communicating that is one to one communication. Now we want to communicate Gurux director tool to multiple meters. can you guys guide us how to communicate with multiple meters.
Srikanth.
3 years 6 months ago
Hi Srikanth, I believe that…
Hi Srikanth,
I believe that you want to use RS-485. There are some differences between the meters, but establish the connection for the meter and read IEC HDLS Setup object, and check what device address. Then set this address for the physical address and establish the connection.
It might be that all the meters are configured to use the same device address, so you need to change that for each meter. All meters in the bus must have a unique device address.
