  3. Problem Connection To SL7000(SL761C010/Q
Problem connection to SL7000(SL761C010/Q
Profile picture for user oulahsensaid
By oulahsensaid , 7 April, 2023
Could you please help me to connect to ACTARIS SL761? Thank you in advance.
GXDLMSDirector 9.0.2302.2001
Log created 21:59:19
Initializing serial connection.
Send SNRM request.
7E A0 08 02 23 03 93 3E 74 7E
Disconnect request
Send Disconnect request.
7E A0 08 02 23 03 53 32 B2 7E
à GXDLMSDirector.GXDLMSCommunicator.ReadDLMSPacket(Byte[] data, Int32 tryCount, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
à GXDLMSDirector.GXDLMSCommunicator.InitializeConnection(Boolean force)
à GXDLMSDirector.GXDLMSDevice.InitializeConnection()
à GXDLMSDirector.MainForm.Connect(Object sender, GXAsyncWork work, Object[] parameters)
3 years 7 months ago
Hi, Your settings look…
Your settings look correct. Change Interface from HDLC to HdlcWithModeE if you try to connect with an optical probe.
Check your cables. It's quite common that that problem is in the cables.
Thank you Mr. Kurumi. I…
Thank you Mr. Kurumi. I tried also HdlcWithModeE. But the meter respond to SLB manufacturer instead of Actaris, I don't know why?
Hi, It's strange if the…
It's strange if the meter returns that it is SLB and not ACE. Are you sure that the meter is ACTARIS SL7000?
Thank you Mr. Kurumi, I…
Thank you Mr. Kurumi, I really appreciate your help.
Type SL761C010/Q 2007
Hi, It might be that this is…
It might be that this is easy to fix. Can you select "View", "Log" and "View Log". Then add those two lines here and I'll verify this.
The first line is like this:
/?!\r\n
and the second line like this:
/SLB\r\n
oulahsensaid
3 years 6 months ago
GXDLMSDirector 9.0.2302.2001…
Log created 20:52:48
IEC Sending:/?!<CR><LF>
HDLC received: /SLB5\2SLB_AMBER_000001<CR><LF>
System.Exception: Manufacturer type does not match. Manufacturer is SLB and it should be ACE.
à GXDLMSDirector.GXDLMSCommunicator.InitSerial()
Hi, I don't know why…
I don't know why manufacturer type is not ACE. You can create a new device template for SLB. The easies way to do it is if you go
C:\ProgramData\Gurux\OBIS
Then copy ace to slb and open it with notepad. Change lines:
<Identification>ACE</Identification>
<Name>Actaris Electricity</Name>
to this:
<Identification>SLB</Identification>
<Name>Schlumberger Industries Ltd.</Name>
Restart GXDLMSDirector and select Schlumberger as a manufacturer.
Let me know if you can read the meter and support for Schlumberger can be added for GXDLMSDirector so you can select Schlumberger automatically from the manufacturer list.
Hi Mr. Kurumi. I do it last…
Hi Mr. Kurumi. I do it last time, according to your response for another old post.
Thank you again for your time and consideration
Regards.
