I have tried to implement gateway functionality in python gurux in Gurux.DLMS.Client.Example
reader = None
settings = GXSettings()
try:
# Handle command line parameters.
ret = settings.getParameters(args)
gateway = GXDLMSGateway()
gateway.networkId = 0
gateway.physicalDeviceAddress = bytearray([0x76, 0x90, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03])
settings.client.gateway = gateway
it did not add my Phy address and increment the wrapper frame size
gurux_dlms version: 1.0.142
gurux_net version: 1.0.20
gurux_serial version: 1.0.20
Authentication: 2
ClientAddress: 0x30
Standard: 0
Security: 48
System title: 41 42 43 44 45 46 47 48
Authentication key: 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36
Block cipher key: 31 32 33 34 35 36 37 38 39 30 31 32 33 34 35 36
TX: 17:39:09 00 01 00 10 00 01 00 1F 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 40 1E 5D FF FF
Hi, There was an issue with…
There was an issue with the gateway. This is fixed for the version 1.0.143.
Thank you same thing with…
Thank you same thing with GXDLMS director
