  3. Authentication Details For Landis Gyr E150
Authentication details for Landis gyr E150
By mekam srilatha , 17 March, 2023
Hello sir,
Can you please tell me what are the client and server address and authentication details for Landis Gyr E150 meter
3 years 8 months ago
Hi, You can connect and see…
You can connect and see the correct settings with GXDLMSDirector if you select Landis+Gyr as the manufacturer. Client address depends from the used authentication level.
mekam srilatha
In reply to Hi, You can connect and see… by Kurumi
Sir I tried with…
Sir I tried with authentication Low and password 00000000
But iam unable to get data
Iam getting failed to get response in a given time
Hi, Can you establish the…
Can you establish the connection for the meter?
Are you getting any data or errors from the meter or are you receiving just time out?
mekam srilatha
In reply to Hi, Can you establish the… by Kurumi
Hi Sir, No. iam unable to…
Hi Sir,
No. iam unable to connect. This is the log which iam getting.
these are the settings
-S COM8:9600:8NoneOne -r sn -c 17 -a Low -P 00000000 -w 1 -f 128 -t Verbose
17:14:44 Initializing serial connection.
17:14:45 Send SNRM request.
7E A0 07 03 23 93 BF 32 7E
17:14:50 Data send failed. Try to resend 1/3
17:14:55 Data send failed. Try to resend 2/3
17:15:00 Failed to receive reply from the device in given time.
17:15:00 Disconnect request
17:15:00 Send Disconnect request.
7E A0 07 03 23 53 B3 F4 7E
17:15:05 Data send failed. Try to resend 1/3
17:15:10 Data send failed. Try to resend 2/3
17:15:15 Failed to receive reply from the device in given time.
at GXDLMSDirector.GXDLMSCommunicator.ReadDataBlock(Byte[] data, String text, Int32 multiplier, Int32 tryCount, GXReplyData reply)
Hi, If you are using serial…
If you are using serial port check that wirings are correct. If you are using optical probe, change start protocol from HDLC to HdlcWithModeE.
