Hi kurumi,
We're trying to connect with the meter model 'DTZ1513' from Inhemeter brand using a secured ciphering connection; We managed to get the DLMS connection settings from the manufacturer, which actually are default key values of DLMS.
However, we are not able to get a valid AARQ response from the meter.
This is the initial connection string which we are using (Anyway we are also attaching the DLMS Director configuration screenshots):
-h xxx.xxx.xxx.xxx -p xxxxxx -c 17 -a Low -P xxxxxxxx -C AuthenticationEncryption -T 49484D01755E1A94 -A 202122232425262728292A2B2C2D2E2F -B 000102030405060708090A0B0C0D0E0F -v 0.0.43.1.2.255 -t Verbose
This is the communication log the software is showing when we try to connect
Send SNRM request.
04:34:41.066 Sent 7E A0 07 03 21 93 0F 01 7E
04:34:41.503 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
RX: 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
TX: 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
04:34:41.503 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
04:34:41.941 Received 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
RX: 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
04:34:41.941 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
04:34:42.456 Received 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1C 90 C2 7E
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1C 90 C2 7E
Disconnect request
04:34:42.456 Sent 7E A0 07 03 21 53 03 C7 7E
04:34:42.878 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send SNRM request.
TX: 7E A0 20 03 25 93 1D BE 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
04:34:42.878 Sent 7E A0 20 03 25 93 1D BE 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
04:34:43.410 Received 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
RX: 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
TX: 7E A0 6B 03 25 10 2C DE E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 35 34 5A 51 41 6F 10 65 79 0C 25 49 79 45 57 71 BE 23 04 21 21 1F 30 00 00 00 1D 66 7E 81 87 D1 78 38 1F 7A C6 D0 C4 C9 C4 72 0A 40 2F 4C B5 D3 88 CF DA 5A DE 31 6F 7E
04:34:43.410 Sent 7E A0 6B 03 25 10 2C DE E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 35 34 5A 51 41 6F 10 65 79 0C 25 49 79 45 57 71 BE 23 04 21 21 1F 30 00 00 00 1D 66 7E 81 87 D1 78 38 1F 7A C6 D0 C4 C9 C4 72 0A 40 2F 4C B5 D3 88 CF DA 5A DE 31 6F 7E
04:34:44.316 Received 7E A0 36 25 03 30 B6 03 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 02 BE 06 04 04 0E 01 06 00 E5 B1 7E
RX: 7E A0 36 25 03 30 B6 03 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 02 BE 06 04 04 0E 01 06 00 E5 B1 7E
04:34:44.316 Sent 7E A0 07 03 25 53 63 A0 7E
04:34:44.816 Received 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
04:34:44.816 Info Closing
04:34:44.816 Info Closed
Thanks in advance,
Can you connect without ciphering using High authentication? I want to verify that your client address and password are correct.
Currently this is the only initial settings accepted by the meter which allows us to read somenthing usefull. We have a "public accces" without ciphering/password (security none) but the client address is 16. That communication is working perfectly but we have no access to meter registers.
Regarding to password and client address we are using, these data were provided by the manufacturer.
Client address 16 for public access (no security)
Client address 17 for read user (HLS or LLS)
Client address 18 for management. (HLS only).
Is there any log that I could send you in order to help figure out what's going on?
thanks in advance!
Can you connect with LLS or HLS without ciphering? Change authentication level to Low or High, set password, and change client address. Can you connect?
I can't. Both connections LLS and HLS are with ciphering as a manufacturer requirement.
I've tryed the following combinations and these are the logs:
BTW, I have set a port forwarding to the meter IP. If you like I could send you a PM with a public and static IP and port to give you access direct to the meter. just let me know.
Thanks for your help!! I really aprecciate it.
client address 17 + LLS + password + ciphering
Send SNRM request.
02:45:45.990 Sent 7E A0 07 03 21 93 0F 01 7E
02:45:46.553 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
02:45:46.553 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
02:45:47.365 Received 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
02:45:47.365 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E
02:45:48.022 Received 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1E 82 E1 7E
RX: 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1E 82 E1 7E
Disconnect request
02:45:48.022 Sent 7E A0 07 03 21 53 03 C7 7E
02:45:48.787 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send SNRM request.
TX: 7E A0 20 03 23 93 CD EA 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
02:45:48.787 Sent 7E A0 20 03 23 93 CD EA 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
02:45:49.522 Received 7E A0 20 23 03 73 CB 2D 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
RX: 7E A0 20 23 03 73 CB 2D 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
TX: 7E A0 63 03 23 10 24 6F E6 E6 00 60 55 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 23 04 21 21 1F 30 00 00 00 1F E4 D4 B5 4D 7A 28 C8 A5 D4 78 37 B2 B6 54 B6 C2 57 D8 7D 92 00 32 53 98 60 95 2F 8D 7E
02:45:49.522 Sent 7E A0 63 03 23 10 24 6F E6 E6 00 60 55 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 23 04 21 21 1F 30 00 00 00 1F E4 D4 B5 4D 7A 28 C8 A5 D4 78 37 B2 B6 54 B6 C2 57 D8 7D 92 00 32 53 98 60 95 2F 8D 7E
02:45:51.050 Received 7E A0 2D 23 03 30 DB D6 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00 12 4E 7E
RX: 7E A0 2D 23 03 30 DB D6 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00 12 4E 7E
02:45:51.050 Sent 7E A0 07 03 23 53 B3 F4 7E
02:45:52.394 Received 7E A0 20 23 03 73 CB 2D 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
02:45:52.394 Info Closing
02:45:52.394 Info Closed
client address 17 + HLS + password + ciphering
Send SNRM request.
02:46:26.896 Sent 7E A0 07 03 21 93 0F 01 7E
02:46:27.521 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
02:46:27.521 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
02:46:28.302 Received 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
02:46:28.302 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E
02:46:28.974 Received 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1E 82 E1 7E
Disconnect request
02:46:28.974 Sent 7E A0 07 03 21 53 03 C7 7E
02:46:29.693 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send SNRM request.
02:46:29.693 Sent 7E A0 20 03 23 93 CD EA 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
02:46:30.427 Received 7E A0 20 23 03 73 CB 2D 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
TX: 7E A0 6B 03 23 10 FC 8A E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 34 03 2E 18 5F 73 06 34 49 49 78 65 0A 17 5B 2B BE 23 04 21 21 1F 30 00 00 00 1F E4 D4 B5 4D 7A 28 C8 A5 D4 78 37 B2 B6 54 B6 C2 57 D8 7D 92 00 32 53 98 60 95 89 F3 7E
02:46:30.427 Sent 7E A0 6B 03 23 10 FC 8A E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 34 03 2E 18 5F 73 06 34 49 49 78 65 0A 17 5B 2B BE 23 04 21 21 1F 30 00 00 00 1F E4 D4 B5 4D 7A 28 C8 A5 D4 78 37 B2 B6 54 B6 C2 57 D8 7D 92 00 32 53 98 60 95 89 F3 7E
02:46:31.599 Received 7E A0 36 23 03 30 6F D5 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 02 BE 06 04 04 0E 01 06 00 E5 B1 7E
RX: 7E A0 36 23 03 30 6F D5 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 02 BE 06 04 04 0E 01 06 00 E5 B1 7E
02:46:31.615 Sent 7E A0 07 03 23 53 B3 F4 7E
02:46:33.256 Received 7E A0 20 23 03 73 CB 2D 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
02:46:33.256 Info Closing
02:46:33.271 Info Closed
client address 18 + HLS + password + ciphering
Send SNRM request.
02:44:16.998 Sent 7E A0 07 03 21 93 0F 01 7E
02:44:17.670 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
02:44:17.670 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
02:44:18.451 Received 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
02:44:18.451 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
02:44:19.123 Received 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1C 90 C2 7E
Disconnect request
02:44:19.123 Sent 7E A0 07 03 21 53 03 C7 7E
02:44:19.763 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send SNRM request.
02:44:19.763 Sent 7E A0 20 03 25 93 1D BE 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
02:44:20.466 Received 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
Send AARQ request.
TX: 7E A0 6B 03 25 10 2C DE E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 54 30 60 4F 68 25 5A 04 1E 23 4E 4F 5C 37 25 78 BE 23 04 21 21 1F 30 00 00 00 1D 66 7E 81 87 D1 78 38 1F 7A C6 D0 C4 C9 C4 72 0A 40 2F 4C B5 D3 88 CF DA 5A DE 49 8D 7E
02:44:20.466 Sent 7E A0 6B 03 25 10 2C DE E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 54 30 60 4F 68 25 5A 04 1E 23 4E 4F 5C 37 25 78 BE 23 04 21 21 1F 30 00 00 00 1D 66 7E 81 87 D1 78 38 1F 7A C6 D0 C4 C9 C4 72 0A 40 2F 4C B5 D3 88 CF DA 5A DE 49 8D 7E
02:44:21.623 Received 7E A0 36 25 03 30 B6 03 E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 89 07 60 85 74 05 08 02 02 BE 06 04 04 0E 01 06 00 E5 B1 7E
02:44:21.623 Sent 7E A0 07 03 25 53 63 A0 7E
02:44:23.310 Received 7E A0 20 25 03 73 12 FB 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
02:44:23.310 Info Closing
02:44:23.310 Info Closed
client address 17 + LLS + password + without ciphering (just trying)
14:48:03 Send SNRM request.
14:48:03 02:48:03.021 Sent 7E A0 07 03 21 93 0F 01 7E
14:48:04 02:48:04.393 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
14:48:04
14:48:04 Send AARQ request.
14:48:04 02:48:04.426 Sent 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
14:48:05 02:48:05.259 Received 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1A 1D 02 00 00 07 D6 FD 7E
14:48:05
14:48:05 02:48:05.293 Sent 7E A0 19 03 21 32 6F D8 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 02 FF 02 00 0B B6 7E
14:48:05 02:48:05.962 Received 7E A0 15 21 03 52 5D 8A E6 E7 00 C4 01 C1 00 06 00 00 00 1E 82 E1 7E
14:48:05
14:48:05 Disconnect request
14:48:05 02:48:05.975 Sent 7E A0 07 03 21 53 03 C7 7E
14:48:06 02:48:06.665 Received 7E A0 20 21 03 73 73 98 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
14:48:06
14:48:06 Send SNRM request.
14:48:06 02:48:06.666 Sent 7E A0 20 03 23 93 CD EA 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
14:48:07 02:48:07.521 Received 7E A0 20 23 03 73 CB 2D 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
14:48:07
14:48:07 Send AARQ request.
TX: 7E A0 63 03 23 10 24 6F E6 E6 00 60 55 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 23 04 21 21 1F 10 00 00 00 1F 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 09 57 A3 69 A8 51 8F 65 E4 69 D6 B0 E5 FB 7E
14:48:07 02:48:07.540 Sent 7E A0 63 03 23 10 24 6F E6 E6 00 60 55 A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 49 48 4D 01 75 5E 1A 94 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 23 04 21 21 1F 10 00 00 00 1F 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF 09 57 A3 69 A8 51 8F 65 E4 69 D6 B0 E5 FB 7E
14:48:09 02:48:09.183 Received 7E A0 2D 23 03 30 DB D6 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00 12 4E 7E
14:48:09
14:48:09 02:48:09.185 Sent 7E A0 07 03 23 53 B3 F4 7E
14:48:10 02:48:10.721 Received 7E A0 20 23 03 73 CB 2D 81 80 14 05 02 01 2F 06 02 01 2F 07 04 00 00 00 01 08 04 00 00 00 01 75 0C 7E
14:48:10
14:48:10 02:48:10.721 Info Closing
14:48:10 02:48:10.722 Info Closed
Finally we manage to solve this issue. It was, as you said, an incorrect Ciphering Key. The manufacturer send us the correct one and with the initial connection string which was written on this thread the meter answered properly.
Now we are facing a associated view getting error on the DLMS Director app. SO I will open another topic and write down the issue.
